Fcd?
Old Apr 7, 2002 | 10:06 PM
Ryde _Or_Die's Avatar
Fcd?
Ok is it a good idea to get a FCD right now? I have an intake only for the time being but will be getting more and more in the next few weeks. Thanks.
Old Apr 7, 2002 | 10:43 PM
:bump:
Old Apr 7, 2002 | 10:45 PM
vosko's Avatar
Just Call Me Terminator!
it can't hurt unless you boost too much when you get full exhaust
Old Apr 7, 2002 | 10:48 PM
I read somewhere that you shouldn't boost over 10psi, even with a FCD. Is that true? Hmmm..seems like I need to get my wastegate ported with a fcd. Then I should get the turbo upgraded while I am at it. Then I should get a boost controller since I got the wastegate ported. Damn...need to buy like everything at once.
Old Apr 7, 2002 | 10:51 PM
vosko's Avatar
unfortunately yes...... look at it this way. do it correctly and you save yourself the $$$ of buying a new engine in addition to the mods
Old Apr 7, 2002 | 10:55 PM
Ok, so what are you saying is the right way? I mean should I just wait for the fcd until I get my larger injectors and s-afc? I want to do it right definitely.
Old Apr 7, 2002 | 10:57 PM
vosko's Avatar
the fcd won't do anything with stock exhaust anyway. if you can try and find a used upgraded ecu then get the 720's s-afc later the car tends to run alot better with a reprogrammed ecu such as gforce, superchips etc
Old Apr 7, 2002 | 11:00 PM
I have thought of that but what do they reprogram it for? I mean what if I get more mods then it is programmed for or different ones? Well I know I want to get the 720cc injectors and s-afc so that I can have the fuel for whatever boost I want to go to(with the stock turbo at least).
Old Apr 7, 2002 | 11:05 PM
vosko's Avatar
most of them are programmed for full mods and you can run with whatever you have and it will just run a little rich. when you need the 720's and s-afc you can get them later and it will be easier to tune with the already mapped ecu
Old Apr 7, 2002 | 11:13 PM
Ok, where do I get this chip
Old Apr 7, 2002 | 11:21 PM
vosko's Avatar
you can also get one for $300 from www.corksport.com just call them or email them. you have to send out your ecu though
Devon300zx
Sep 17, 2015 03:50 PM
Devon300zx
13
Sep 2, 2015 08:16 AM
Snook
21
Sep 1, 2015 06:32 PM
