Purchased RX 7 Wont Start
Old Sep 13, 2007 | 01:26 PM
dvs71990's Avatar
I just bought this new 1990 Rx 7 NA from a used car sales man,not running. He told me one day it just decided not to run. Car turns over. It sat for 4 years. Ive done everything. It has fresh gas and oil. new battery, he had put new plugs 4 yrs ago. I ve done the unflooding procedures. Used starting fluid. But nothing. When I remove the bottom leading plugs they shoot out fire, what does that mean? The plugs seem to always be wet with gas and oil. I know plugs are getting spark because i ve manage to shock my self with all of them. I need help what should I do.
Old Sep 13, 2007 | 02:01 PM
X-JaVeN-X's Avatar
Drive.
do a compression check...if it sat for 4 years, it may have a stuck seal
Old Sep 13, 2007 | 02:40 PM
freemanrx7's Avatar
^Hold On
You could try the trans fluid trick.
Old Sep 13, 2007 | 03:28 PM
dw89s5's Avatar
i know nothing
more info needed
is it sputtering popping or just nothing
i hope u got that car real cheap
Old Sep 13, 2007 | 04:24 PM
blwn rtr 89''s Avatar
i put up a post awhile ago trying 2 debate the best product 2 remove carbon deposite without block taredown.
this may help get u started
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/what-substance-s-could-free-up-seals-carbon-deposits-687113/
Old Sep 13, 2007 | 04:55 PM
InsomniacFC's Avatar
Will drive for parts
Get your money back + get another running RX-7 = WIN
Old Sep 13, 2007 | 05:52 PM
dvs71990's Avatar
how much atf should i add?
Old Sep 13, 2007 | 06:02 PM
Boosted11's Avatar
Pistons are gay
NOOOOOOOOOOOOOOO ATF!!! Oil!
Why did you buy a non running rx7, when you dont seem to know alot about them? You also say that you bought it from a car salesmen...Im gonna only assume you got ripped off?
Old Sep 13, 2007 | 06:49 PM
dvs71990's Avatar
I did some extensive research on it. I bought the car with the intent to rebuild it. I used oil it didnt get the job done. i even put some starter fluid, now how come it didnt start, is my spark not strong enough.? by the way i do not like the attitude in this forum with newbies.
Old Sep 13, 2007 | 07:15 PM
micah's Avatar
Winter sucks
No ATF....
Use 2cycle oil.. put an ounce or so in each leading plug hole.. re-install plugs.. fire her up.
Old Sep 13, 2007 | 07:47 PM
freemanrx7's Avatar
^Hold On
I bought a car that wouldn't start. I added a tablespoon of ATF to each plug hole. It fired right up. Doesn't mean it will work for you but it did for me. Some people say that the transfluid is bad for the internals. My motor is still running strong 2 years later.
You could try tow starting it. TRY pushing starting to.
Something else could have caused it to not run all of a sudden. Make sure you double check for vac leaks esp after the AFM cause it will not idle.
Did you do a compression test?
Also buy a new set of factory NGK plugs. This will really help even if they are somewhat new.
I learned to ignore people with bad attitudes!!!!!!!!!
Old Sep 13, 2007 | 07:53 PM
RX7KENN's Avatar
FirsTGeN
Long time members read so much of this ****, their not being rude.
but everything thats possible to talk about has ALREADY BEEN COVERED.
and it gets annoying seing 10 of these a day by N0oBZ.
But I'm not trying to offend no one !! ^^
Old Sep 16, 2007 | 09:05 AM
beastyrx7's Avatar
hey mate
why dont you try a mechanic that specialises in rotaries,
that would be your best bet.
if you have tried every thing then thats what i woudl be doin,
cheers
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1973rx3
SE RX-7 Forum
Sep 10, 2015 07:35 AM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
rexhvn
Aug 19, 2015 02:59 AM
Joe rawket
Aug 11, 2015 02:46 PM
