s4 and s5 turbo the same?
Old Sep 13, 2007 | 06:48 AM
vangsplace's Avatar
my turbo has gone bad and Im in need of a new one....i have a 1988 10th anniversary Turbo II....wasnt sure if the turbos are interchangeable, im looking for images to compare but can really find much. Has anyone had experience or installed an s5 turbo on an s4 engine before? thanks
Old Sep 13, 2007 | 07:01 AM
forced inducted fd dude's Avatar
brap brap brap
i did it everthing bolts up, oil line, water line,. you gotta use the s5 manifold then bolt the s5 turbo, btw the s5 has a bigger hotside and only one waste gate need
left is s4, right is s5 the openings airnt the same on the s4 but on the s5 there both the same
the compressors are the same
the waste gate housing are diffrent but you still wanna port them
Old Sep 13, 2007 | 08:14 AM
7dust's Avatar
Irregular Here
If you do not want to change manifolds - you can use an S5 turbo by swapping the turbine housings.
Old Sep 13, 2007 | 08:54 AM
vangsplace's Avatar
Thank you guys so much!!...So I just need s5 turbo and the manifold and everything should bolt up and work fine ? Sweeeet. I just figured an s5 turbo would have a little less miles...but is the s5 turbo better? Would it be worth it to just swap my bad turbo with an s4 one or better to just get the s5 manifold and turbo?
Old Sep 13, 2007 | 08:59 AM
SpeedOfLife's Avatar
rotors excite me
arguably the S5 turbo is a little better, it's designed without the twin scroll system of the S4 turbo yet to my understanding has the same or slightly greater power potential as the S4. So a couple fewer parts and systems to break on the S5 turbo. as far as miles it all depends. maybe on average for every stock turbo ever sold there'd be a trend, but in a month long time span you look for a turbo you could wind up with turbos having anywhere from 20k to 200k miles on them, S4 and S5.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
