Power FC Tps Adjust On Fc
Old Sep 13, 2007 | 01:12 AM
Boost Lee's Avatar
Dark Lord of the Drift
Tps Adjust On Fc
So are there any instructions for getting the TPS on a S5 TII with an authentic AP Engineering PFC adjusted? I can't seem to get the lights to come on at the check connectors. I'm just frustrated now.
Old Sep 13, 2007 | 02:46 AM
Iwan's Avatar
quite easy task.
you need:
a: Comander
or
b: Datalogit
Comander use:
go to etc menu, than to sensor check. Check the voltage for TPS1 und TPS2. Adjust the voltage to the specs (0.1-0,7 TPS1 and 0,75-1,25 TPS2)
Datalogit:
Same as the Comander, but with Datalogit- Log function.
Hope this will help.
REgards
Iwan
Old Sep 13, 2007 | 12:32 PM
cewrx7r1's Avatar
Eye In The Sky
Some people just do not study the owners manual, and actual play with the adjustments to learn.
How do people think that us senior PFC experts got this way. We taught ourselfs!
Old Sep 14, 2007 | 03:25 AM
Iwan's Avatar
quite simple to answer: we did RTFM !! and the others, don't...
REgards
Iwan
Old Sep 14, 2007 | 08:29 PM
Barry Bordes's Avatar
"Elusive, not deceptive!”
Originally Posted by Iwan
Comander use:
Also the sensor check voltage lights-up when out of range.
Barry
Old Sep 14, 2007 | 09:38 PM
fc3s91's Avatar
R.I.P Mark( Icemark )
Barry
This nolonger applys with the pfc. I have tried. The only way is what Iwan said.
Thanks Robert
Old Sep 15, 2007 | 05:10 AM
charge's Avatar
i had my TPS1 illuminated black under sensor check (same as you AP.Engineering which is in fact a FD PFC anyway)
it was at 0.28v and the car stalled at deceleration, had bad idle sometimes, and the need kept beeing at 1500rpm. i adjusted the screw at the throttleplates rod to 0.31v and had no problems with idle and stalling again.
Old Sep 15, 2007 | 11:02 AM
Boost Lee's Avatar
I have looked through the FSM so many times. However the test light method no longer applies when the PFC has been introduced. The resistance values aren't exactly specific enough to get the desired idle and throttle response......RANT ON!!!!!!!!! So what do I do when the owners manual doesn't apply? I ask questions hoping the "senior experts" could provide more assistance that just "study the owners manual".
I understand how it can be, hearing questions so many times you want to punch the next person that asks in the nose. But if you (or anyone else) is such an expert, why keep coming back to the forum? You don't need to learn anymore, right? Apparently, you don't ask any questions... and since you don't provide answers, why waste time here?
I really hate to write this because I specifically respect all the contributions you have made to the forum, cewrx7r1. I think I'm just more pissed at some of the other vats of good information that have chosen to go the route of "RTFM noob!!"
I'll be honest, when I checked my subscribed threads to see if anyone had responded to my post and saw your name, I was sure I had an answer.... DOH!
Oh well, I'm done. RANT OFF!!
Old Sep 15, 2007 | 01:03 PM
fc3s91's Avatar
tps2 should read in voltage on your commandor between 0.75-1.25v (Closed throttle). Throttle full open should be Approx 5v. TPS1 should read between 0.25- 1.25v (Closed throttle). Open throttle 4.1-4.4v. If your adjustments are on the nose, than you have to go water temp correction. That is were I would start. Also have you calibrated your map sensor? The book I learned from was a tunier name Chuck Westbrook. I hope that gets you started.
Thanks Robert
Old Aug 27, 2009 | 08:18 AM
phunny's Avatar
On the FC you're talking about the Sensor Sw Check right? If so I don't see a tps1 or tps2 anywhere... I bought the car with PFC in it so I'm still on the steap end of the learning curve.
-charlie
Old Aug 27, 2009 | 07:58 PM
Ranzo's Avatar
^^^ that is because it is VTA1 and VTA2. You should be concerned with VTA2. That is the low range portion of the sensor and affects idle the most. need to adjust that to roughly 1v when engine is warm
Old Aug 28, 2009 | 07:45 AM
phunny's Avatar
Thanks alot, I was thinking I was blind.
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
Turblown
Sep 30, 2015 05:58 PM
rotor_veux
Sep 28, 2015 09:25 PM
