found this in my oil pan...?
Old Sep 12, 2007 | 08:34 AM
Rotor Nut.
found this little screw in my oil pan. looks untouched and as if it just fell off. i went through the manual but could not find it. anyone know where it is from? thanks in advance.
Old Sep 12, 2007 | 08:47 AM
Houstonderk's Avatar
My girl
Looks like the tip of a drain plug.
Old Sep 12, 2007 | 08:50 AM
Rotor Nut.
the tip of the drain plug has something that screws into it? never knew that, ill check it out right now...
Old Sep 12, 2007 | 09:03 AM
pfsantos's Avatar
(blank)
No, maaan, more likely one of the oil control screws that go in the eccentric shaft.
Old Sep 12, 2007 | 09:20 AM
Aaron Cake's Avatar
Engine, Not Motor
It's not an oil jet from the eccentric.
No idea what it is really. I can't think of anything in that area resembling that part other then the setscrew used to hold the setscrew on the oil pump. Without a size reference though it's hard to tell.
Old Sep 12, 2007 | 09:23 AM
SirCygnus's Avatar
whats going on?
its some random screw that happened to be the same color as the oil pan so whoever put the oil pan on there didn't see it.
Old Sep 12, 2007 | 10:06 AM
Rotor Nut.
its a small screw. appears like a 6mm thread. its not the eccentric shaft screw i check that one. i am pretty stumped myself. maybe it is just an annomous screw.
Old Sep 12, 2007 | 12:30 PM
Infosponge's Avatar
I love rx-7's
that little thing gose into the bottom of the oil pump. It holds the bottom peace of the oil pump steady so it does not spin or something. I found that same thing in my oil pan too. You need to put it pack in and make sure it is lined up with the grove it goes into and use some lock tight to make sure it dosent come off again. If you dont you will lose oil pressure. I think that is wy I lost alittle oil pressure in my car. Aaron is right!
Old Sep 12, 2007 | 07:15 PM
Rotor Nut.
thanks guys that was where it was from. appreciate everyones help.
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
sypath
Aug 16, 2015 12:06 AM
