Is it safe to use a blowtorch on the flywheel nut?
Old Sep 10, 2007 | 06:47 PM
Sideways7's Avatar
I know its OK and basically required to get the front pulley nut off, but can you do the same on the flywheel nut? I realize it usually isn't necessary, but it is in my case. I'm afraid I'm about to break my breaker bar (its already bending) and I'm basically jumping on it, but it won't budge.
Old Sep 10, 2007 | 06:50 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
My son. Rent yourself a decent impact gun. Your life will be much easier.
Old Sep 10, 2007 | 07:01 PM
Lizo7's Avatar
When i had to do this i read you can torch it but i just wouldn't trust myself to not ruin anything back there.
I bought the humongo wrench thing from racing beat and took a couple whacks with a 4x4in fence post to knock that sucker loose. But like hozzmanrx7 said best bet rent an impact, i know I'm buying one before I've got to do that again.
Old Sep 10, 2007 | 07:03 PM
takahashiRyosukeFC3S's Avatar
1 miracle from sainthood
impact gun, i just did mine about a month ago.
Old Sep 10, 2007 | 07:13 PM
Sideways7's Avatar
Thats what I did last time, but some ****** stole it. Anyone else that cares to answer my question? I'm already well aware of the option of using an impact wrench, I just want to avoid it if possible.
Old Sep 10, 2007 | 07:15 PM
ericgrau's Avatar
Clean.
I hope you don't plan on re-using any bolt that you torch for too long. It'll change the strength of the material. Then again, I don't know how long "too long" is. And for steel the surface is affected more than the inside, which often is a desirable thing (hard shell without embrittling the innards). But point is if you torch something anything could happen to its strength, you don't know what, and you might regret it later.
Old Sep 10, 2007 | 07:21 PM
Sideways7's Avatar
I don't care about the nut, I have a few spares. I just wanted to make sure there wasn't a possibility of damaging the e-shaft.
Old Sep 10, 2007 | 07:26 PM
Slammedblk7's Avatar
Yes its slow
No strenf? I never have problems..
Old Sep 10, 2007 | 07:30 PM
Sideways7's Avatar
Its not a matter strength, I was jumping on the damn thing.
Anyway, I finally got it off. I just bounced on it for a while and it finally broke loose. Never had this much trouble with any of my others.
Old Sep 10, 2007 | 07:31 PM
Yes its slow
I think she likes you.
Old Sep 10, 2007 | 08:23 PM
eagleheart's Avatar
i went through the same thing like 2 weeks ago. lock up the fly wheel and use an air impact wrench an electrical impact wrench doesnt have anough power
Old Sep 10, 2007 | 08:55 PM
iceblue's Avatar
Passing life by
You need a bigger firmer rod to please her my friend.
LongDuck
Oct 7, 2015 08:12 PM
NickNac113
13
Oct 1, 2015 09:25 PM
