Losing fuel pressure
Old Sep 10, 2007 | 01:13 PM
Mike7's Avatar
Could it be that my aeromotive FPR is bad?? When I'm at full boost no matter how much more fuel I add the car leans to 13:1 afr and I my fuel pressure gauge does a nose dive and bounces off zero. What could lead to this??
Old Sep 10, 2007 | 01:16 PM
iceblue's Avatar
Passing life by
Bad pump no gas or FPR
Old Sep 10, 2007 | 01:22 PM
J-Rat's Avatar
Alcohol Fueled!
Forgive Iceblues cryptic post, he is a moron.
What he meant to say was:
You either ran out of fuel as in you dont have any more fuel pump left to keep up with your fuel demands
OR
your pump is starting to give out due to age/wear
OR
Possible your FPR took a nosedive, but thats not likeyl.
How about you give us your mods, including your pump/injector size/PSI demands/etc...
Old Sep 11, 2007 | 06:29 AM
Mike7's Avatar
Well I have an aeromotive a1000 with 1000cc primaries and 1680 secondaries. It used to do the same thing when I was running a denso pump, that's when I upgraded to the a1000. Just wanting to know if there could be anything else that could cause a loss in fuel pressure. Thank you
Old Sep 11, 2007 | 06:34 AM
RotaMan99's Avatar
Do you have a fuel pressure gauge or are you basing your "fuel pressure" problem on the fact that you can't go richer?
Old Sep 11, 2007 | 11:29 AM
iceblue's Avatar
Passing life by
ahh Jay always being so kind at heart. You still mad about the hot sauce, damn. Thx for confirming my post hehe.
Old Sep 11, 2007 | 02:02 PM
Mike7's Avatar
My car runs extremely rich all the time but i've seen it on the dyno twice after I supposedly fixed the fuel pressure problem but the needle( on the fuel pressure gauge mounted to the FPR), when I start surpassing 8psi, starts dropping and it get's lean all of a sudden. It's a weird problem and my only thought is now that maybe I'm losing voltage, because of my S4 alt, or my FPR is going bad.
Old Sep 11, 2007 | 02:29 PM
SpeedOfLife's Avatar
rotors excite me
isn't it possible that you're dumping so much fuel that your fuel line pressure drops and you also simply can't supply enough fuel? that's probably not a good thing to sustain for long, but it makes sense that it could happen...
Old Sep 11, 2007 | 02:49 PM
X-JaVeN-X's Avatar
Drive.
How is your wiring setup? I don't know about the a1000 pump...if it's plug and play like the walbro's then you may need to rewire the pump?
Old Sep 13, 2007 | 05:19 AM
Mike7's Avatar
Any other suggestions???
Old Sep 13, 2007 | 05:57 AM
TehMonkay's Avatar
Back in the game
Relay to the pump, check your fuel filter.
Running 13:1 isn't good under boost, quit that before you blow it up.
Old Sep 13, 2007 | 06:16 AM
RotaMan99's Avatar
if you have 13+ volts at idle at the fuel pump you should have that or more while boosting.
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
