12a project
Old Sep 9, 2007 | 09:36 AM
bakon420's Avatar
12a project
hi, i just bought a reliable 1985 12a rebuild off my friend. i want to put that motor in my 1985 chevette.it cam with the aternator, beehive, and the intake manafold and carburetor. i was going to take the off to clean the motor up abit and to clean the carb. but in afraid if i take the carb off im not going to remember where stuff goes.
aslo would the brake booster and the hydraulic clutch setup work in my car.
where could i find a book or something to tell me where to coolant and old lines go
Old Sep 9, 2007 | 11:27 AM
warwickben's Avatar
Registered shy guy
get a hanes guide for a car with the motor ur useing . it should have all the info for hooking it up ect. i would go with all the stock brake parts for that car you can, i could be wroung but the car your putting the motor in is pretty heavey compared to a rx7 and it mite not be able to stop it.
Old Sep 9, 2007 | 11:43 AM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
I dont know if you mean you are going to put the RX brake stuff in or not, but I would keep the vette braking system and find a way to hook the vacuum line for the brake booster to the RX manifold.
I would recommend running the RX transmission, so you would need to use the clutch master and slave to operate it. This is the easiest way to put it in the car, without having to do bellhousing work to mate your vette transmission to the RX engine. You will also need a custom driveshaft.
Dont forget your engine mount bar, I think it is called subframe?
Feel free to correct where I am wrong.
Old Sep 9, 2007 | 11:58 AM
bakon420's Avatar
hey my car is lighter than a rx-7... its i believe 16-1800lbs and the 12a it way lighter than the stock motor
Old Sep 9, 2007 | 12:00 PM
bakon420's Avatar
i have a 5spd tanny for the 12a... i will get some pics of the car and the motor with tanny
Old Sep 9, 2007 | 01:02 PM
bakon420's Avatar
http://i116.photobucket.com/albums/o...0/100_0473.jpg
http://i116.photobucket.com/albums/o...0/100_0470.jpg
http://i116.photobucket.com/albums/o...0/100_0469.jpg
http://i116.photobucket.com/albums/o...0/100_0474.jpg
Old Sep 9, 2007 | 04:21 PM
bakon420's Avatar
would anyone recommend me using the stock carb or should i get a new one?
Old Sep 9, 2007 | 04:54 PM
FBsliderseven's Avatar
domokun!
its up to you.
if you want more power get a after market one like a weber or holley carb.
Old Sep 9, 2007 | 06:51 PM
bakon420's Avatar
well on a webber or a holley is there any vacuum lines on them? the carb on my car right now has them and i hate them
Old Sep 9, 2007 | 07:20 PM
Jeezus's Avatar
There are lines on my manifold for the brake booster, None on my carburetor.
erick31876
Sep 23, 2015 05:16 AM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
