tire sizing question, math maticians.....how will it affects gear ratio?
Old Apr 7, 2002 | 03:11 AM
FC3AZ's Avatar
Ok, stock tire size on my SE is 185/70/14, according to Tire Rack. If I bought 2 tires for the rear, in size 205/55/14, how much would that effect my gear ratio?
Old Apr 7, 2002 | 03:15 AM
UniqueTII's Avatar
Slow and old
This is a tough question, because the height of the tires, although supposedly determined by the width divided by the aspect ratio, is not the same brand by brand.
Old Apr 7, 2002 | 03:25 AM
FC3AZ's Avatar
I will do some simple math, and probably make myself look like a moron.......
185 / 70 = 2.64285
ok......now......
205 / 55 = 3.72727
so, this will definately have an effect on my final gear ratio. i know the car has 4.10's. but, tire height also plays a part in all this.
Old Apr 7, 2002 | 04:08 AM
hypntyz7's Avatar
http://www.miata.net/garage/tirecalc.html
Old Apr 7, 2002 | 04:16 AM
FC3AZ's Avatar
oh sweet, that link is very cool. But, I still am lookin for someone to come up with a gear ratio for me..........something that would be higher than 4.10 cause of the shorter tire? or would it be lower than 4.10?
Old Apr 7, 2002 | 02:19 PM
FC3AZ's Avatar
bump.....
Old Apr 7, 2002 | 04:13 PM
NZConvertible's Avatar
I'm a boost creep...
UniqueTII is correct, the maths isn't reliable because tire manufacturers obviously don't know how to use a ruler! But we can use it as a guide.
A 185/70x14 tire should be 615mm in diameter, a 205/55x14 should be 581mm, which is ~5.5% smaller. This would be the same as changing to a 4.34:1 diff. You should always aim for the original overall diameter; the closest profile for that width is 205/65x14 (Ø622mm).
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
