Engine break-in Question
Old Apr 6, 2002 | 01:31 AM
AdamP's Avatar
I just rebuilt my motor and was wondering about going up hills. Is it better to let the engine rev-up keeping the bost low or keep the revs low and let it boost. The housings and bearings are the originals, but Apex seals and all other seals are new. Plus the Engine has a street port. Thanks.
Old Apr 6, 2002 | 03:43 AM
Nameless's Avatar
Rx7.com has a little section that talks about breaking in. It says not to go over 4k, and some other stuff.
Old Apr 6, 2002 | 05:39 AM
rynberg's Avatar
You can call one of the tuners like KD Rotary, but I would say if no one's behind you, just let the car slow down.... Actually, I think letting the car rev a little past 4k would be better than more than light boosting on the car.
Old Apr 6, 2002 | 09:52 AM
Lost Time's Avatar
Chimera Driver
Never lug the motor, especially while breaking it in. And according to Pettit, you are NOT rpm-limited when you break in a new motor. You should be using all of the rev range, just at limited (5psi) boost.
Old Apr 6, 2002 | 11:11 AM
7-sins's Avatar
thats not paint....
500 miles under 3k, oil change
1000 miles oil change, 100rpm increase every 100 miles
2000 miles oil change
Old Apr 6, 2002 | 04:50 PM
Swamp RX-7's Avatar
best thing to do is a lot of stop-and-go driving for the first 1000 miles, of course do like 7-sins stated, but try not to boost higher than 5psi, and try to use a lot of different rpms.
Old Apr 6, 2002 | 04:57 PM
93TTRX7's Avatar
how can you not boost more than 5 psi?
Old Apr 6, 2002 | 04:59 PM
Swamp RX-7's Avatar
Just be light on the throttle, when I cruise around town, I'll sometimes never boost at all, well maybe 1psi, but nothing major.
Old Apr 6, 2002 | 05:05 PM
rxrotary2_7's Avatar
i would say light foot, or boost controler
Old Apr 6, 2002 | 06:41 PM
T88Rx7's Avatar
regular speed limit
Old Apr 6, 2002 | 06:46 PM
CYM TKT's Avatar
hey, your car is on fire!
"regular speed limit" LMAO!!! so true... so true...
Old Apr 6, 2002 | 09:18 PM
Lost Time's Avatar
Chimera Driver
Whoever rebuilt the motor should have "looped" the boost control to limiit you to 5psi. If they haven't you need to either install a boost controller (Home Depot bleeder valve is fine), or be VERY careful with the throttle. I suggest the former. Then at 1000 miles, let 'er loose.
Professorpeanutrx7
Aug 15, 2015 01:38 PM
ncds_fc
Aug 15, 2015 10:06 AM
