ATF Treatment - Any hope before a rebuild?
Old Apr 5, 2002 | 08:08 PM
85RX7GS's Avatar
Unhappy ATF Treatment - Any hope before a rebuild?
Do you think that maybe, by some slight chance, that the ATF treatment will help my car - maybe loosen up some frozen apex seal springs?? I'm going to try it tomorrow and let it sit overnight.
Old Apr 5, 2002 | 08:11 PM
riffraff's Avatar
smog nazi destroyer
what are the symptoms of your engine?
there is always a possibility of it working, and the **** is cheap enough, so give it a try..
Old Apr 5, 2002 | 08:32 PM
85RX7GS's Avatar
it basically runs really rough and accelerates very slowly. the engine shakes a bit when ideling also
Old Apr 6, 2002 | 03:23 AM
V8kilr's Avatar
with the shaking it sounds like the apex seal may be broke,or just badly worn,
ah well atf it,
how could it hurt???
$4.00 or less
go down some post,maybe on page 2 and look for my pics and complete how to.
Old Apr 6, 2002 | 10:56 AM
peejay's Avatar
Old [Sch|F]ool
ATF generally only "fixes" engines that have been sitting for a very long time, like in a junkyard, or engines that have an excess of carbon buildup due to improper tuning or generally not driving the car hard (which is often why they end up in the junkyard). If the engine has the symptoms of a blown apex seal, it most likely DOES have a blown apex seal.
Old Apr 6, 2002 | 02:28 PM
82transam's Avatar
Never Follow
This is sort of along the same lines: My 83 has 99k on it and seems to still run pretty strong. Should I try the ATF treatment anyway to see if it would make it run any better? Also does ATF screw up your cat? Anyway just wondering. Peace
Old Apr 6, 2002 | 04:14 PM
hanman's Avatar
I would strongly suggest disconnecting your cat before doing the ATF trick. If you use too much you can melt the thing down. Ask me how I know.
hanman
Old Apr 6, 2002 | 09:20 PM
82transam's Avatar
Never Follow
OK I'll bite; how do you know? Anyway, my car seems to run fine but there is always room for improvment, that's why I asked. Thanks Peace
Old Apr 6, 2002 | 09:32 PM
V8kilr's Avatar
with your miles, "99,000" i would do it more for piece of mind rather then looking for hp gains,
in my book its definetly considered general maintnance at 100,000 miles,
go for it,
but remove that cat
Old Apr 6, 2002 | 09:42 PM
82transam's Avatar
Never Follow
Yea, when I said improvement I meant reliability, smoothness, etc not HP. I'd assume the HP gains would probably be minimal anyway. The thing I'm afraid of is destroying the cat and entire exhaust system in the process of removing it to do this. Hmmm the letters RB are coming to me.......
Peace
Old Apr 6, 2002 | 09:44 PM
V8kilr's Avatar
there ya go,
buy an rb exhaust then atf it before you put the exhaust on,
i still have not yet put on my new exhaust cause i wanted to wait until i atf'ed it
good luck
Old Apr 6, 2002 | 09:49 PM
82transam's Avatar
Never Follow
Thanks dude, now; to get my *** down to the gas station where I work to make some money to get some RB on my car. Oh boy this is gonna take awile at $6/hour. Sheesh
Old May 16, 2002 | 10:38 PM
ghetto-rx7's Avatar
man u only get 6 bux and hour???
wen i was 13 i got 8 bux an hour!!
Old May 17, 2002 | 07:26 AM
82transam's Avatar
Never Follow
Bite Me! Yep $6 an hour pumping gas. Fun (not) I got $8 under the table last summer doing construction and I will do that this summer again so I should get some good $$$$ for my car soon. I hope..........
Old May 17, 2002 | 07:28 AM
85RX7GS's Avatar
Wow, I thought this post was LONG gone...
Old May 17, 2002 | 07:36 AM
82transam's Avatar
Never Follow
This post was long gone untill ghetto-rxt brought it back from the dead.
Old May 17, 2002 | 08:51 AM
inittab's Avatar
I read your email
And now that your 14, what do you make?
Old May 17, 2002 | 09:00 AM
Directfreak's Avatar
I am a Jeeper Now.
Under PSI
19
Sep 23, 2015 11:47 PM
mulcryant
Sep 9, 2015 05:24 PM
SCinfidel
Sep 8, 2015 05:36 PM
