Oil pressure
Old Apr 5, 2002 | 02:45 AM
JumpyRoo's Avatar
Oil pressure
At random, apparently, sometimes my gauge will be at zero, and then hop back up to mid range. Whassa deal?
Old Apr 5, 2002 | 05:59 AM
sending unit, loose wire. might went out all together. had to buy a new guage.
Old Apr 5, 2002 | 07:03 AM
go_speed_go's Avatar
I had that problem.
It was a loose wire on the sending unit.
Pull the wire off, clean the contact point with some sandpaper and you should be fine.
Old Apr 5, 2002 | 07:45 AM
RETed's Avatar
Make sure the oil pressure sender capacitor is secure.&nbsp This little black plastic box the size of a "piece of gum" is normally secure on one of the bolts on the clutch slave cylinder.&nbsp During clutch jobs or engine/trans removals, these things are almost always forgotten and not secured.
-Ted
Old Apr 5, 2002 | 08:28 AM
JumpyRoo's Avatar
Well, then. More loose wires.
When I get new gauges, I'll fix it. Until then, *slaps car* She'll be fine.
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
13
Sep 4, 2015 06:54 PM
andyvideopro
Aug 20, 2015 10:55 AM
