? about how to install a ProfecB in a Ser5 T2
Old Apr 5, 2002 | 02:18 AM
Jerk_Racer's Avatar
I tried to install a ProfecB on my kouki (series 5) Turbo2. I followed the instructions but it doesn't seem to work. It's the same when on or off. I used it with and without the pill that I found in the vacuum line. How should the dip switches on the back be set? I know I must be doing something boneheaded. Can anybody set me straight if you've already installed one youserlf.
jerk_racer@hotmail.com
Old Apr 5, 2002 | 01:47 PM
Jerk_Racer's Avatar
Oh come on now! Somebody has to have done this before. I did a search, but that didn't offer much insight.
Old Apr 5, 2002 | 03:04 PM
Dyre's Avatar
Your Opinion is Wrong
Set it for internal gated.
The 'in' nipple on the steeper motor box should go to a positive pressure source. The 'out' should go into the wastegate nipple. The vacume line on the back of the profec should also go to a posstive boost source.
Old Apr 5, 2002 | 03:34 PM
fastrotaries's Avatar
W. TX chirpin Monkey
it should be up, down, down, up
Old Apr 5, 2002 | 03:41 PM
vosko's Avatar
Just Call Me Terminator!
make sure you have it installed close to the wastegate or else it won't work. my friend had that problem on his sr20det
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
