Which boost controler.
Old Aug 15, 2007 | 10:21 PM
swif's Avatar
Almost back together
Question Which boost controler.
I have searched a few forums on this and can oly find old info. Not sure if anything has changed. I have a power fc and I am going to a single turbo. I will be in need of a boost controler. I will go with an electrical unit. I am looking to get the AVC-R to match the pfc. I also looked at the Profec E-01.
Should I stay with the apex and keep these matching in makers? What would be the best route to go? Would like input from you guys that have run with these boost controls. More info the better.
Thanks
Old Aug 15, 2007 | 11:07 PM
dregg100's Avatar
old school greddy profec B
Old Aug 16, 2007 | 06:51 AM
BLitzed33's Avatar
The apexi AVC-r is great because you can do gear dependent boost for traction etc....but if you want simplicity and ease of use, then the greddy type S boost controller is for you, its the newer version of the old school profec b. It has three *****, set the two settings and you're done. Thats what I had on mine.
Old Aug 16, 2007 | 03:04 PM
doridori-rx7's Avatar
Navy MarCom
blitz SBC type R is great, it may not do gear dependant boost but the twin solenoid controller and volume/gain control system is far superior to the pressure read singles solenoid setups.
Old Aug 18, 2007 | 10:49 AM
signofinfinity's Avatar
Coyote
Apexi.....
Old Aug 18, 2007 | 05:35 PM
cewrx7r1's Avatar
Eye In The Sky
There are two great ones: Blitz SBC i-D and Blitz DSBC Type R.
My DSBC Type R keeps boost constant between summer and winter without any changes! And it has over boost protection if someone has only messed with your normal boost setiing.
For over boost caused by control hose failures or boost control failures with a PFC, setup the PFC for it.
Old Aug 18, 2007 | 05:57 PM
Jason's Avatar
The one
I have been selling a lot of the AEM Tru boost. Cheap and does a good job of controlling boost.
http://www.rx7store.net/product_p/ae...controller.htm
Old Aug 20, 2007 | 05:32 PM
apexFD's Avatar
Just a quick question...
Does the greddy type S boost controller have a built in turbo timer?
-Ben
Old Aug 21, 2007 | 10:37 PM
spiritrmazda's Avatar
I just bought an HKS EVC V, I'll let you know how it works when I finish installing it.
Old Aug 21, 2007 | 11:08 PM
slow7NC's Avatar
Slow
Greddy Profec B Spec II
Old Aug 22, 2007 | 09:01 PM
willub and company's Avatar
Pobody's Nerfect
I have the Gizzmo IBC. very neat display and easy install as well as being very reliable and doing its job correctly. the price tag wasn't bad either
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
