voltage at the fuel pump on TIIs
Old Apr 4, 2002 | 02:54 PM
SiyahGTU's Avatar
Everybody seems to be concerned about the voltage on modded cars. Why can't we install a voltmeter and connect it to the fuel pump to read the voltage at the pump to keep an eye on the issue?
Old Apr 4, 2002 | 03:07 PM
RETed's Avatar
Sure, you can do that...
Problems?&nbsp I've got got too many gauges to look at right now!
I'm waiting for MoTeC to design a NICE back-lit ADL so I can throw away all those gauges!
-Ted
Old Apr 4, 2002 | 03:21 PM
NZConvertible's Avatar
I'm a boost creep...
Don't you like this one? I want so bad...
Old Apr 4, 2002 | 03:36 PM
RETed's Avatar
NO!&nbsp That backlight with the LCD SUCKS!
http://www.walbro-tdd.com/Data/Engli..._features.html
It's a reverse LCD with true backlighting that I wished MoTeC had done.&nbsp It's a much better contrast under "dark conditions."
-Ted
Old Apr 4, 2002 | 04:16 PM
It's a reverse LCD with true backlighting that I wished MoTeC had done. It's a much better contrast under "dark conditions."
Yeah, I see what you mean, much better looking. Ever stuck your head into a WRC Impreza? That's very similar to what they use. Very cool!
Old Apr 4, 2002 | 04:18 PM
RETed's Avatar
You gonna make me slap you upside the head for bragging???
The only time I'd get a chance if those puppies make our crappy ProRally circuit by the SCCA.&nbsp It's such a MUTED race versus a true FIA WRC race!
-Ted
Old Apr 4, 2002 | 04:30 PM
86Rx7GXL's Avatar
What should the voltage be at the fuel pump on a stock 87 Turbo 2?
Old Apr 4, 2002 | 04:40 PM
Well since you asked...
I've worked for the NZ Rally for the past few years in the Service Parks. Basically assembling, controlling, marshalling and disassembling. There is no other way to get any closer to all the teams and cars, including all the WRC guys. It's amazing what you can get away with wearing an "Official" swinger! WRC rocks!
You can start slapping now!
Old Apr 5, 2002 | 04:15 PM
86Rx7GXL's Avatar
Anyone? what should the voltage at the fuel pump on a 87 turbo?
Old Apr 5, 2002 | 04:26 PM
I wish I was driving!
12V or higher at WOT
Old Apr 5, 2002 | 04:54 PM
86Rx7GXL's Avatar
**** hmm this may be my problem i just went out and hook a meter to it showed about 9 till around redline then how 11-12. one time i seen it do the higher volt at 5 but only the one time, should i see a change when reving it?
Old Apr 5, 2002 | 04:58 PM
try the fuel pump rewire. Your voltage doesn't look too bad though.
Old Apr 5, 2002 | 05:00 PM
86Rx7GXL's Avatar
witch 2 wires should i be hooking to? to check the volts?
Old Apr 5, 2002 | 05:02 PM
the two wires going to the fuel pump. Really, you need someone lying in the back of the car with a DMM while you drive under load.
Sean
Old Apr 5, 2002 | 05:08 PM
86Rx7GXL's Avatar
theres 4 wires going to the pump just not sure witch 2 are to the pump and 2 are for level. Is the voltage suppost to change any threw driveing/ idle?
Old Apr 5, 2002 | 05:12 PM
In the rear of the car, leading through the fuel pump cover plate, there are two wires. Check there.
An extra ground on the pump never hurts.
Of course,neither does a sumped tank with an inline pump and twin filters
Sean Cathcart
Edit: (been drinking, last day of class). Yes, voltage at idle and very light throttle will be much lower than at WOT,
Old Apr 5, 2002 | 05:14 PM
86Rx7GXL's Avatar
what kind of reading should i get without the car running just with the ignition on?
Old Apr 5, 2002 | 05:16 PM
7 or 8 volts? not very high for sure. Wish I could give you exact specs, but I always use a custom wired inline pump.
I would'nt worry about upmp voltage at idle. You'll never detonate and pop your motor at idle.
Worry about getting 12V at WOT with all of you accessories on, such as lights, a/c, stereo, etc.
Sean
Old Apr 5, 2002 | 05:22 PM
86Rx7GXL's Avatar
well with the key on with out the car running i dont get any volts, at idle to 6800 RPM i get around 9.2 thats also driving down the road WOT. guess i should try rewireing it
Old Apr 5, 2002 | 05:26 PM
That would require a fuel pump rewire, I think. Or a custom wired pump
Sean Cathcart
shutup_billy@hotmail.com <-- any q's......
Old Apr 5, 2002 | 06:18 PM
OK, the ECU controls a resistor and relay in the engine bay that runs full battery voltage to the pump at start up and under high load, and cuts it down to ~9V the rest of the time. Improves pump life apparently, and it's safe to assume that the pump is sized to suit this variable voltage and the ECU's fuel maps were also written to take this into account.
Here's a link on how to rewire the fuel pump to improve voltage to the pump, which can drop over the years as the wiring deteriorates through age. This is recommended for ANY TII, but I would consider it imperative if you're upgrading your pump. The procedure in the above link will be much easier to understand if you print out the fuel pump wiring diagram on page 50-34 of the 88 FSM. The section on the fuel pump in the EFI chapter (page 4B-72) is also useful.
Good luck!
Old Apr 6, 2002 | 12:36 PM
86Rx7GXL's Avatar
thanks alot guys, im gonna go ahead and rewire it for now, but i want to try sticking another ecu in it cause theres still other little problems that i dont have any clue what could cause them other than a messed up ecu
immanuel__7
89
Sep 5, 2015 10:23 AM
82streetracer
Aug 23, 2015 09:28 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
