Sponsored by: CARiD
Prob with webber fed 12A
Old Aug 14, 2007 | 09:18 AM
jono010's Avatar
Newbie
Unhappy Prob with webber fed 12A
Having major problems with my webber fed 12A. Leaning out at high RPM. I assumed it would be fuel pump, so replaced that with a carter pump able to handle up to 15psi... currently running a reg a 6 psi. Now there is another problem with this, and that is that i can not get the pump to maintain a constant psi and will not reach over 6 psi. There are no leaks from reg or pump... so i have no idea!!!!
Old Aug 14, 2007 | 06:21 PM
Sgt.Stinkfist's Avatar
premix, for f's sake
weber carbs work best between 2.5-3.5 psi...4 max. the fuel pump is more than likely not the issue, its more likely jetting related ie). too small main jet , too big air corrector, wrong emulsion tube...many possabilities
Old Aug 14, 2007 | 07:20 PM
jono010's Avatar
Newbie
ok... yeah well it is running 13b jets. Had been advised it would be better off running it too fuely then not enough. so i might change them back to 12a jets and see how it goes. cheers
Andrew7dg
Aug 6, 2017 01:41 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
