Intake Air Temp Sensor
Old Apr 4, 2002 | 01:00 PM
Lost Time's Avatar
Chimera Driver
I seem to have developed a problem with my intake air temp sensor. Most of the time it will read just fine. But maybe once a week, it will start reading between -10 and 0 celsius. Has anyone ever experienced a similar problem? Does anyone know exactly where the temp sensor is? I know it resides under the UIM mounted in the rear-most runner. I'd like to be able to grab it and give it a shake, to see if the wiring is loose, without removing the UIM. Any other suggestions besides a loose wire or busted sensor?
Old Apr 4, 2002 | 01:34 PM
Bacon's Avatar
IRS 4 Life
its on the primary runner to the rear rotor...the sensor dies all the time from what i hear..
Old Apr 10, 2003 | 09:23 PM
jpandes's Avatar
Does anyone know what the symptoms are of a bad Intake temp sensor gone bad???
Old Apr 11, 2003 | 12:26 AM
duboisr's Avatar
It does not yell when you pinch it . It is the one with the blue connector
Old Apr 11, 2003 | 12:37 AM
poss's Avatar
Slower Traffic Keep Right
have you been drinking tonight? all of your replys have been......."creative"
Old Apr 11, 2003 | 05:24 AM
DrPJM1's Avatar
I would suggest moving the intake air temperature (IAT) sensor from under
the upper intake manifold (UIM) to somewhere between the intercooler outlet
and the throttle body. The UIM acts like a huge heat sink and never lets you
read true IAT once you have heated it up. You can reach the IAT from the
firewall, reach in about the middle. It's the only harness that goes to that
location. You can cut the wires and extend them to the new location. You can
plug the location or order a new sensor and go from there. The net gain is
better response to IAT changes.
Old Apr 11, 2003 | 03:46 PM
wonder1and's Avatar
I Sold My Car 2 the Devil
Mine was doing the same thing... I replaced it and well it doesn't do it anymore... cost about 50 bucks! ouch! Its under the UIM and I think it is possible to replace it using a open end wrench... I say pull the uim and go from there... once it is off it will take about a min to switch.
Ryker
Old Apr 11, 2003 | 05:02 PM
xph's Avatar
xph
Anyone else move their IAT?
Snoopy FD
Dec 8, 2015 01:45 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
