Help!....Both dash lights and parking lights stopped working!!
Old Apr 4, 2002 | 11:56 AM
halfMty's Avatar
Unhappy Help!....Both dash lights and parking lights stopped working!!
I need you guys help. I have a 86 Rx-7 and the dash and parking lights stopped working. I've checked all of the fuses, but I'm stomped now!! They have to be related, because I saw them flicker a few night ago and now they're dead!!
If you know how to fix this please post it!
Thanks.
Old Apr 4, 2002 | 12:25 PM
rico05's Avatar
WTB S5 N/A FC
The CPU might need to be resoldered. Do a search for "CPU cold solder". Good luck!!
Old Apr 4, 2002 | 01:52 PM
Amur_'s Avatar
Refined Valley Dude
And pull the headlight switch itself (best to take it to an electronics shop for this.) The contacts inside (which are a big PITA to get at) wear down after 16 years.
Ditto on checking the CPU. It controls most/all non-engine electronics.
ttyl,
Amur_
Old Apr 4, 2002 | 01:54 PM
tmak26b's Avatar
Get a new headlight switch
Old Apr 4, 2002 | 02:41 PM
halfMty's Avatar
The headlight switch? My headlights work. It's the rear lights and the dash light. Does the headlight switch control the dash and the rear parking light?
Thanks...
Old Apr 4, 2002 | 02:54 PM
gold87na's Avatar
SRT-4 User
This just recently happened to me. What ended up happening on my 87 was a (-) wire going into the headlight switch got hot, melted and then burned my headlight switch out. I (having experiance) took the headlight switch apart and rebuilt it for about $25. Then to replace the wire I went to a local import salvage yard and got the harness. The harness is very easy to change too. It's about 1'6" goes from the headlight switch to next to the fuse box. Inside of the switch the parking lights and the int. lights both run off of the same wire comming into the switch unit. So they both could go at the same time. They also sell headlight switchs on ebay for like $20 i think.
Old Apr 4, 2002 | 03:05 PM
halfMty's Avatar
Where exactly is the headlight switch??
Old Apr 4, 2002 | 03:55 PM
BlackRx7's Avatar
Daily Domestic Killer
on the left side of the instrument cluster, you have to take it off, I had the same problem and just resoldered the white and black wire that was grounding out, that fixed my prob
CaptainKRM
14
Aug 26, 2015 09:52 PM
runner83
1st Gen General Discussion
16
Aug 26, 2015 05:16 PM
andyvideopro
Aug 20, 2015 10:55 AM
fastsaab
Aug 19, 2015 11:42 AM
