Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
gas turbine swap
Old Aug 6, 2007 | 07:38 PM
wackaloo13's Avatar
gas turbine swap
has anyone ever swapped a gas turbin into a rx7
Old Aug 6, 2007 | 08:50 PM
Ragnaroek's Avatar
What's a gas turbin?
Old Aug 7, 2007 | 06:12 PM
American Rice's Avatar
gas turbines are used by like power engineers and other people that work with boilers and feedwater systems. I have never seen one, but they would be HEAVY though
Old Aug 7, 2007 | 09:33 PM
Chemical's Avatar
not necessarily.. what about an allison 250-c20 or similar, same engine that powers bell 206 helicopters, makes over 400hp and is roughly the same size as a 13b, probably weighs less too
Old Aug 8, 2007 | 12:06 AM
Ragnaroek's Avatar
gas "turbin"
Old Aug 8, 2007 | 02:09 AM
AUGieDogie's Avatar
its a jet engine that uses a propeller shaft to apply power instead of the thrust of the hot gasses. I read an article about 20 years ago, where they put one in a corvet. They said it ran phenominaly, and of course sounded like a jet engine. They also said that the exhaust was so hot that it would melt the asphault at stop lights.
It propels thing like helicopters, hydro planes, some passenger ferrys, and many many military ships.
I think you would have a great deal of trouble routing the exhaust gases out. But it would be really really fun.
Old Aug 8, 2007 | 06:11 AM
PDF's Avatar
PDF
Talking
Heres one that was fitted to a small aircraft for a while, then replaced with a 20B turbo. The turbine itself is light and compact, its the reduction box thats heavy. This one originally came from a ground power unit, used to run airconditioning for jumbo jets while they're at the terminal. I forget how much power it made... 3 or 400hp.
It wouldn't be hard to fit to a vehicle, you would need some sort of trick auto trans and just split the exhaust in 2 and run out each fender!
Old Aug 8, 2007 | 08:41 PM
KaoticFdR1's Avatar
Be a Hero...Punch a Koala
old news i know but heres a reference
THIS
POWERS THIS!
weighs 138lbs (engine) from Bell Ranger Helicopter
Old Aug 8, 2007 | 09:02 PM
now's Avatar
now
I think this type of engine would be great connected to a generator that
could spin up 1 to 1 with the turbine. then have electrics at the wheels.
a hot rod insight
Old Aug 9, 2007 | 04:20 PM
KaoticFdR1's Avatar
*delete*
Old Aug 11, 2007 | 05:52 AM
Narfle's Avatar
Rx7 Wagon
No, because theyre devastatingly impractical for automobile use. Power comes on seconds after you engage the throttle. Power also stops seconds after you engage the throttle. Stop and go traffic would be...inconcievable.
Old Sep 4, 2007 | 12:42 AM
cozmo kraemer's Avatar
Darkside FD
A gas turbine as an electrical generator that power electrical motors, and charge batteries, that drive the vehicle seems like a cool idea. Turbines are far more efficient with far greater longevity and reliability.
it would be fun to try and engineer a car like that...
Old Apr 1, 2008 | 01:58 PM
Whizbang's Avatar
Respecognize!
cvt transmission
Old Apr 1, 2008 | 02:35 PM
philiptompkins's Avatar
Originally Posted by Low Impedance
cvt transmission
yes, and useing the brakes would help too.
Old Apr 1, 2008 | 02:49 PM
Joker1337's Avatar
Water Boy
necro'd.
Old Apr 8, 2008 | 11:56 AM
AXMDR787BOY's Avatar
I am mad JDM tyte
It would be insanely loud and hot, but it could work.
Old Apr 17, 2008 | 09:39 PM
impactwrench's Avatar
[QUOTE=AUGieDogie;7214938] I read an article about 20 years ago, where they put one in a corvet. They said it ran phenominaly, and of course sounded like a jet engine. They also said that the exhaust was so hot that it would melt the asphault at stop lights.
That article was in HotRod over 40 years ago, The car was built and owned by Vince Granatelli, son of Andy Granatelli, Founder of the STP co. I remember reading that the car idled at 60 MPH. All brakes at speeds below that. There was a picture in it that showed burnout marks down the entire quarter mile.
ChrisRX8PR
Aug 21, 2015 01:56 PM
smikels
Aug 18, 2015 01:26 PM
Engine stand ready
Aug 14, 2015 10:26 PM
