Can someone please post where stock water temp gauge reading sits???
Old Apr 2, 2002 | 10:53 PM
skotx's Avatar
Registered Abuser
You don't need a pic, and you need to chill a bit. It should be in the dead center, pointing straight at 9 o'clock or a hair below. If it starts going north, you should start getting nervous. Wire up the fan switch mod so you can control your fans in stop and go traffic, etc.
http://rx7.voodoobox.net/howto/fanswitch/fanswitch.html
Old Apr 3, 2002 | 11:57 AM
martini's Avatar
as long as it's just sitting stable anywhere NEAR the midpoint, you are fine, you don't need a pic, honestly.
if you understood how the gauge works, you'd understand that.
Old Apr 3, 2002 | 12:03 PM
Bacon's Avatar
IRS 4 Life
hmmnn deja-vou(sp?)
https://www.rx7club.com/forum/showth...threadid=63269
Old Apr 3, 2002 | 12:24 PM
rynberg's Avatar
Re: Can someone please post where stock water temp gauge reading sits???
Originally posted by rx7kcass
Man i beg you guys to please post a pic of the water temp gauge, i need to satifsy my self where the water temp reading should be, please someone out there please take a pic of there reading or something and post it here, i will be getting my aftermarket watertemp gauge very soon, but for the time being i'am stuck with the stock piece of **** gauge. is the reading like horizontal but slightly close to the white hot line??
Not be harsh, rx7kcass but you can be TOO paranoid about this car. You need to relax a little or owning this car is going to kill you. Your gauge is working fine. As long as it's stable, your car is fine. Besides, if you're that worried now, getting your aftermarket gauge will probably give you a coronary. That needle moves all over the place, and sitting in hot traffic will not be comforting. (All reasons why the stock gauge is so middle oriented in the first place.)
Old Apr 3, 2002 | 12:28 PM
Bacon's Avatar
IRS 4 Life
why dont you take a pic of yours and everyone can tell you its fine
Old Apr 3, 2002 | 01:43 PM
Lost Time's Avatar
Chimera Driver
In the six months I went without an aftemarket gauge the ONLY time my stock needle went above 9 o'clock is when it overheated. As long as it stays below center, relax. Rynberg is right though, if you do get an aftermarket gauge, you're going to need a Prozac prescription to go with it.
Old Apr 3, 2002 | 02:44 PM
Cetchup's Avatar
The Cursed FD
I guess im pretty much fucked then...My stock gauge will sometimes go up and then back to center. But i know i havnt overheated. ****!!
Old Apr 3, 2002 | 02:58 PM
BrianK's Avatar
it doesn't matter much where it is as long as it doesn't move. The exact position it stops is different in every car.
Old Apr 3, 2002 | 05:16 PM
Lost Time's Avatar
Chimera Driver
Can you be sure the person you bought it from didn't already linearize the stock gauge?
Old Apr 3, 2002 | 05:49 PM
Jonesboro's Avatar
Here's something to read and look at about the stock temperature gauge:
http://www.geocities.com/sdrx7_club/tempgauge.html
Old Apr 3, 2002 | 05:57 PM
juliof's Avatar
The problem is "normal" or the needle being horizontal on the FD temp guage can be 240F!.And even though you might have never over heated, or the temp guage needle has never moved up the low speeds fans dont turn on untill 230F this is "normal". No wonder these motors over heat or have o-ring problems.
sherff
Feb 24, 2019 12:09 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
LMBTG
Aug 15, 2015 01:43 PM
