Sponsored by: CARiD
non running 88 n\a
Old Apr 2, 2002 | 08:36 PM
non running 88 n\a
I got an 88 n\a for an awsome deal.
But, It doesnt run. I checked for fuel and spark and I got it. I also used a piston compresion gauge and it read 45 pounds in each spark plug hole. Thats not good but it would seem the consistency of the readings in each hole would mean it should run. Right?
I also have a bad smell of gas after I try and crank it and the plugs were wet. This thing doesnt even try to crank and I dont really wana go for a new motor or a rebuild just yet. What do you guys think my next step should be?
Old Apr 2, 2002 | 09:31 PM
RETed's Avatar
Push-start it...
-Ted
Old Apr 3, 2002 | 03:21 AM
Felix Wankel's Avatar
Super Newbie
Which plug holes did you use? The top ones are where you take the compression reading. Also search for how to unflood a rotary engine.
Old Apr 3, 2002 | 06:16 AM
I read the unflooding method and I will do that this afternoon.
I tested all four plug holes and they were all the exact same reading.
Old Apr 3, 2002 | 08:42 AM
Super Newbie
Were you leaving the other plugs in? Having all 4 plugs out will give you a low reading.
Old Apr 3, 2002 | 01:23 PM
Ryde _Or_Die's Avatar
Flooded
Old Apr 3, 2002 | 02:06 PM
FPrep2ndGenRX7's Avatar
Don't you have to remove the schrader valve from the compression tester to verify the needle it jumping evenlly for each rotor face while the motor is turning over?
Old Apr 3, 2002 | 05:20 PM
Thank you soooo much guys, I did the unflooding technique and shes running great!!!
Old Apr 3, 2002 | 05:27 PM
Told ya
Old Apr 4, 2002 | 05:45 AM
Super Newbie
I just hold the button down. Does the same thing.
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
The Shaolin
Sep 14, 2015 07:50 PM
