Microtech TPS reads 99% at light throttle
Old Jul 24, 2007 | 11:59 PM
Funkspectrum's Avatar
Is this right? I have the TPS zeroed out at idle but it seems a little much to be at 99% during light throttle...
It's an S4 TII with an LT8...
Old Jul 25, 2007 | 10:44 AM
Rotorhead34's Avatar
Scream baby Scream!!!
You may need to re-calibrate the tps. If the adjusting screw is too far in/out( I don't remember which), it will read fast. 00 should be at the first moment of movement of the plunger and 99 at the end or there about. Lesson I learned from trial and error.
Old Jul 26, 2007 | 03:42 PM
Thats what I thought. I was wondering why my gas mileage was horrible while cruising...
Old Jul 27, 2007 | 06:32 AM
FD3UK's Avatar
S4 only has a narrow range TPS, it will show 99% by 1/4 - 1/3 throttle opening, the TPS will have no effect on your fuel economy. When calibrated correctly Microtech only uses the TPS to switch between idle and load maps.
To improve fuel economy at cruise use a wide band and adjust cruise map to get best feel for power and good AFR. I run a half bridge and find best AFR is 12.5-13,on stock ports you may get away with 14.5-15.
Old Jul 28, 2007 | 10:11 AM
Aaron Cake's Avatar
Engine, Not Motor
The Microtech basically only uses the TPS to tell when the car is at idle or not. As such, you can use the stock narrow range, a simple switch, etc. If you want things more accurate for datalogging, then you can install a full range unit.
Queppa
Nov 18, 2024 03:47 AM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
incubuseva
14
Sep 3, 2015 12:37 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
