Exhaust turbine affects ????
Old Apr 2, 2002 | 02:35 PM
milkman2k52's Avatar
I'm pretty sure the compressor size affects the spool up and top end, but how exactly does the exhaust side's size matter? Thanks I know its a newb question I've just been wondering for a while....
Old Apr 2, 2002 | 09:46 PM
RETed's Avatar
You can't make generalizations like that.&nbsp A turbocharger is a complex mechanical device that needs to be custom tailored for each specific application.&nbsp You can't just slap parts together and slap it on the engine and expect it to work.
As a rule, compressor size give you potential peak power.&nbsp Turbine wheel and housing A/R dictate power band (moreso the A/R).&nbsp Turbine wheel trims dictate the "efficiency" of the turbo, and has a little to do with "lag" due to turbine wheel mass.
You might want to read Hugh MacInnes' "Turbocharging" (a bit dated) and/or Corky Bell's "Maximum Boost" books for esoteric information on turbos and their terms.
-Ted
Old Apr 2, 2002 | 10:34 PM
Well at least i know what im going to do with my next paycheck...
Buy Maximum Boost!!
Old Apr 2, 2002 | 10:45 PM
RICE RACING's Avatar
Buy the other book RETed mentions, it is money better spent, hell I still refer to my copy every no and then.
Corkys book is good if you wan to buy expensive toilet paper
Old Apr 2, 2002 | 10:46 PM
Corkys book is good if you want to buy expensive toilet paper
dillrx7
Sep 7, 2015 09:38 AM
doritoloco
Sep 5, 2015 12:41 PM
apooch
Sep 4, 2015 10:27 AM
