clutch and flywheel ?'s
Old Jul 12, 2007 | 12:45 PM
WhiteBoyzRacing's Avatar
i was wondering if a clutch and a flywheel that is made for the t2 will bolt right up to a n/a with out anymods. i bought a clutch and a flywheel for a turbo by accident for my 87 n/a. thanks guys
Old Jul 12, 2007 | 01:00 PM
classicauto's Avatar
Crash Auto?Fix Auto.
The turbo flywheel will bolt up to the N/A engine. Provided they are the same series and the counter weights are the same it'll run fine also.
Only snag is that you'll need a TII transmission as well.....and then a TII driveshaft....TII diff....TII half shafts...
Old Jul 12, 2007 | 01:23 PM
well it looks like they are going back lol. thanks for the help
Old Jul 12, 2007 | 01:24 PM
TehMonkay's Avatar
Back in the game
Or you could get a TII transmission and the mazdatrix TII to NA driveshaft.
Old Jul 12, 2007 | 09:33 PM
RETed's Avatar
Actually, that's not correct.
Yes, the flywheel and PP will bolt up.
The problems is that you'll need to match the clutch DISC to the transmission.
The Turbo II clutch disc is a 1" spline.
The non-turbo FC is a 7/8" spline.
Technically, you can stuff a non-turbo clutch disc with your set-up and have everything work.
All of that probablyt confused the hell out of you.
-Ted
Old Apr 21, 2010 | 11:36 PM
kekoa's Avatar
another question
ok so what if i have an n/a s4 motor and a turbo s5 trans w/flywheel and clutch... would it bolt on? and if so what kind of counterweights would i need?
sinclair7seven
11
Sep 11, 2015 10:15 AM
risingsunroof82
Sep 9, 2015 08:06 PM
Enzo1944
Sep 6, 2015 08:57 AM
