Fallowup Stuck in Miami Afriad to drive
Old Jul 12, 2007 | 02:06 AM
cyberxn's Avatar
Remove this account
Talking Fallowup Stuck in Miami Afriad to drive
ok First off i made it home
But here's how i did it....
Every ....50-60 Miles i had to Pull over to a 711 or some place.
and get a Samwich bag of Ice... and put one on the lead Coil and one on the trailling..
This WORKD well to the point to where i could get here...
that being said.
do the Coil packs have some kinda lame Fail safe for heat?
What would Cause them to heat up to that Point.
and i think thats the Oddest thing ive Done so far with that RX
LEmme know please
Old Jul 12, 2007 | 02:14 AM
RETed's Avatar
Where is the original thread?
Are you running the stock ECU?
If so, there's no reason why the coils are overheating unless you're grounding them wrong or they are arcing badly.
-Ted
Old Jul 12, 2007 | 02:19 AM
cyberxn's Avatar
Remove this account
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/stuck-miami-afriad-drive-670201/
I donno but the Ice workd :/
Old Jul 12, 2007 | 03:28 AM
RETed's Avatar
Walbro?
The 255 one?
Yeah, it's overkill.
It's fouling your spark plugs.
That could cause the coils to get hot and possibly arc.
-Ted
Old Jul 12, 2007 | 03:31 AM
cyberxn's Avatar
Remove this account
Yes the 255.... i bought it from Ebay after asking around.. it seemd to be the best bet.
so what Pump works best?
AND.. can somone Better explain Limp Mode?
And would a Fuel Pressher Regulator Possibly fix or help correct the problem?
i just dont wana start 5 new threads
Any Info would be Great
AIM: cyberxn
Y! gothic_blood2002
MSN cyber_computer_repair@hotmail.com
Ty you all for all your help.. if there's anything i can do lemme know
Old Jul 12, 2007 | 05:50 AM
RETed's Avatar
The Walbro is pumping too much fuel into your engine.
More accurately, the Walbro 255lph is pushing so much fuel that your fuel pressure is higher than stock spec.
With the higher fuel rail pressures, the fuel injectors are shooting too much fuel into the engine.
Do you monitor your gas mileage?
I bet your car is eating gas like crazy.
10mpg?
I'd recommend to put back a stock fuel pump.
Good used units are easily found in the classifieds section...or just ask anyone if they have one for sale.
Non-turbo FC's are always being parted out, and fuel pumps are really cheap.
All the Walbro units are too "big" for your non-turbo.
Even the smaller 190lph unit is too big.
Getting and aftermarket FPR could fix your problem, but it's an expensive option to go that route?
You can dial down the fuel pressure to stock spec, and it should work okay.
I would still recommend to get a good, used non-turbo FC stock fuel pump - it's easier and cheaper this way.
-Ted
Old Jul 12, 2007 | 08:08 AM
wthdidusay82's Avatar
Rotary Power
Listen to ReTed he knows his stuff!! As far as that walbro pump, I'd just sell it to someone who actually needs it.
Old Jul 12, 2007 | 10:45 AM
TehMonkay's Avatar
Back in the game
I have a stock NA fuel pump, wanna trade the walbro and i'll throw some cash in on top?
bzebern
274
Apr 21, 2019 11:39 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
fastsaab
Aug 19, 2015 11:42 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
