Cross post!! Help, where to read RPM voltage?
Old Apr 1, 2002 | 12:01 PM
the_saint's Avatar
I am trying to datalog my RPMs, but I need a voltage output.
Is the signal from the ECU to the tachometer a voltage signal?
Which wire should I tap into?
Or do I need to get another tach circuit board and read off of that?
Thanks
thesaint
p.s. for whoever is interested I am planning on datalogging my MAP voltage, wideband o2 sensor output, and rpms to tune the car.
Along that note, does the InterAcq software for the EFI PMC allow you to log other inputs? As far as i understand all possible inputs to the PMC are already used.
Old Apr 2, 2002 | 01:36 AM
RETed's Avatar
RPM signal is usually a pull-down voltage (i.e. negative).&nbsp So the wire will typically "float" then go to "0" when you get an RPM pulse.
-Ted
Queppa
Nov 18, 2024 03:47 AM
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
