Separating rear trailing arm from hub carrier
Old Apr 1, 2002 | 10:28 AM
junior-coyote's Avatar
Is there a trick to separating the trailing arm from the "toe control hub" (aluminum hub carrier)? It seams to be hung up on the two rubber bushings. I don't want to hit it with a hammer too hard. Manual just says to unbolt it. This is a 91 NA coupe.
thanks.
Old Apr 2, 2002 | 01:21 AM
RETed's Avatar
You can use an "idler rod seperator" or a generic pickle fork.
-Ted
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
TheAsset
Sep 5, 2015 04:36 PM
GrossPolluter
Aug 15, 2015 10:32 PM
