does this make any sense?
Old Jul 8, 2007 | 12:01 PM
xeccentric's Avatar
Non-op
ok so i was working at kragen yesterday so this guy came in looking for clutch fluid so naturally i gave him dot 3 brake fluid. anyways he said he was selling his car. after i asked what car said rx7 and my eyes lit up. but there was one thing that kinda troubled me. he said that the car wasnt startinng cause there was no clutch fluid and the clutch wasnt engaging. does tat make any sense cause im planniing on buying the car....
Old Jul 8, 2007 | 12:24 PM
clokker's Avatar
Cake or Death?
No, it doesn't.
Make sense, I mean.
The clutch pedal does have to be depressed when starting- there is a switch, similar to the brake light switch, on the pedal- but that switch could care less if there is fluid in the system or not.
Assuming the transmission is not stuck in gear, if the pedal is pushed in, the car should start.
Old Jul 8, 2007 | 12:47 PM
jonesfromindia's Avatar
Goofyrotor
doesnt make no snez.
dont buy it.
Old Jul 8, 2007 | 01:07 PM
xeccentric's Avatar
Non-op
more on the clutch swithc...if that were to give the car wouldnt start...correct? how much would a new clutch switch cost from mazda? any ideas?
Old Jul 8, 2007 | 04:43 PM
clokker's Avatar
Cake or Death?
You could probably bypass the switch or a used switch from the junkyard would be well nigh free, I'd guess but that's unlikely to be the cause.
That sort of switch seems almost bulletproof and your (potential) car has something else going on if it's not starting.
Let him go ahead and refill/bleed the clutch hydraulics though...one less thing for you to do.
Old Jul 8, 2007 | 11:02 PM
SpeedOfLife's Avatar
rotors excite me
just go try changing the fluid, if you want a '7 brake fluid is cheap, you wouldn't be out much if it didn't work.
jsesq
27
Sep 25, 2015 11:10 AM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
