Sponsored by: CARiD
synthetic mix
Old Jul 5, 2007 | 01:32 PM
black_turbo_FC's Avatar
synthetic mix
Used pennzoil 10w30 synthetic blend in my 13b it makes great oil pressure and idles very smooth, but now the car is slow as *****, it wont boost hardley over 2psi and if you get on it fairly hard from a dead stop it hesitates very bad then finally picks up at about 3k. Not really asking a question just kind of posting an experience. I will be switching it out with conventional today. (Maybe thats why the owners manual says to not use synthetic )
Old Jul 5, 2007 | 04:36 PM
diabolical1's Avatar
welcome to the board.
dude, your oil is not causing what you describe. start looking elsewhere (ignition system, vacuum leaks, wastegate control, etc.). when was your last tune-up?
by the way, the short version of the Mazda/synthetic oil-thing is they are not allowed to tell theit customers not to buy specific brands of oil and i believe they had a beef with Mobil a long time ago.
on a more self-serving note, have you ever considered Amsoil?
Old Jul 5, 2007 | 06:00 PM
I just bought the car last week and before i bought it i had the dealership do a tune up on it, or so they said they did, but the plugs are brand new wires are new from what i can tell, i always use at least 89 octane, and this started happening right after i changed the oil so that is why i am confident it is the oil. Im not sure of vacuum lines though. And actually i was considering amsoil that is why i tried a synthetic to se how it would perform, and after i saw if the results of a synthetic were positive i was going to get amsoil or torco.
Old Jul 10, 2007 | 02:30 PM
86inthe530's Avatar
atf i heard you can use atf as oil what would that do?
Old Jul 10, 2007 | 03:55 PM
atf as oil will get you a new engine.
Old Jul 13, 2007 | 12:36 AM
initial D is REAL!'s Avatar
Well, I have heard of people using atf in cyl engines to help free up sticky hydrolic lifters. Its not 100% atf though, maybe jsut a quart or less i believe
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
BLUE TII
Sep 26, 2015 10:12 PM
Captain Hook
Sep 22, 2015 01:12 PM
