Mix and Match Transmissions
Old Mar 31, 2002 | 02:39 PM
Question Mix and Match Transmissions
Can you put a Turbo II 89-91 tranny on a 90 non-turbo engine thats in a 88 Rx-7?
Old Mar 31, 2002 | 03:28 PM
darkwaveboi's Avatar
Need donor car in Fairfax
you...CAN...but..wouldnt an ECU change be for the better since the engine is 'different'? Also, i still havent come across a definate answer as to if you are able to use the auto driveshaft to link the tII tranny and the na diff.
Old Mar 31, 2002 | 03:29 PM
Aaron Cake's Avatar
Engine, Not Motor
Yes, but you will need to use the TII starter, TII slave cylinder and custom driveshaft.
Old Apr 1, 2002 | 08:54 AM
Rob500's Avatar
The auto drive shaft will not fit. It is about 2 inches too short.
Rob
Old Apr 2, 2002 | 11:53 AM
well can you use a non turbo 89-91 tranny on a non turbo 90 engine thats in an 88?
20B Forum
21
Mar 22, 2022 01:00 PM
Joe428
Sep 29, 2015 06:58 PM
