wich wire is ground on Pressure Sensor
Old Mar 31, 2002 | 09:39 AM
von's Avatar
von
For the 89-91 models. Im giong to ground it.
Old Mar 31, 2002 | 09:45 AM
SaabGuy's Avatar
on a 1987 tII the ground is the Brown with the Black strip.
The other three wires are Black with white strip, Brown with red strip, and Brown with yellow strip. So if all those wires are the same, then its your Brown with black thats your ground. You can test it with an ohm meter to the negative bat terminal to be sure, although if you have bad grounds, you will read pretty high ohms when doing that.
Old Mar 31, 2002 | 09:58 AM
von's Avatar
von
THNX
Snoopy FD
Dec 8, 2015 01:45 PM
FullFunctionEng
Full Function Engineering
Aug 25, 2015 08:17 PM
20B Forum
Aug 18, 2015 02:46 PM
eddierotary
Aug 16, 2015 04:12 PM
