1600 cc injector deal..
Old Mar 30, 2002 | 11:42 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
I am buying a package of 8 , 1600cc injectors locally in order to save a few bucks for my to4e install, 4 of them are spoken for, there will be 4 left over, if anyone is looking for a couple of 1600's, I will sell the leftovers for what I paid for them + shipping, which is 104.00(canadian dollars) + shipping, I know this should be in the for sale section, but its only the turbo guys that need 1600 cc injectors..104.00 canadian is about 66.00 US..Max
Old Mar 31, 2002 | 01:05 PM
AJatx's Avatar
Have they been flow tested?
Are they low or high impedance?
What kind of injectors (Bosch, RC)?
Thanks,
J
Old Mar 31, 2002 | 06:06 PM
Maxthe7man's Avatar
Brand new Ford motorsports injectors...I was told they are low impedence, but i am not going to stick to that, they end up being high impedence..
I have been getting alot of PM's on these injectors, they are dirt cheap thats for sure, I have only 4 for sale and they are pretty much spoken for right now, but if someone else wants to organize something, I can pickup another set of 8 and send them to whoever wants to organize the buy...Max
Old Apr 1, 2002 | 10:58 AM
Ehughes's Avatar
I'm interested in any GB put together on these!
Old Apr 1, 2002 | 12:14 PM
Morbius's Avatar
Why not just get the ones from http://www.precisionte.com/
They are $90 each and here is the description...
Bosch 160# Injectors
This injector will flow some serious fuel. Up to 1900HP!! Please note, these injectors are low impedance and will require a ECM modification. Accel or SpeedPro users do not need this modifiaction.
$ 90.00
They are 1680cc I think.
-Morbius
Old Apr 1, 2002 | 12:27 PM
rotorracing's Avatar
hey Maxthe7man do u need a ECM modification to run your 1600cc injectors
Old Apr 1, 2002 | 07:29 PM
Maxthe7man's Avatar
Rotorracing.. Yes, remove ecu from car, toss it in garbage, and install haltech e6k in space where ecu once resided..Max
Old Apr 2, 2002 | 06:15 PM
amemiya's Avatar
lol well you have to have some way to control it. atleast a afc. If you just through them in I feel sorry for the car behind you when they kick in. lol
Old Apr 2, 2002 | 07:17 PM
jspecracer7's Avatar
1JZ powered
apexi s-afc would not be enought to control it. the s-afc works on the map sensor voltage, and adjust the stock ecu as such. The problem you will run into is that the s-afc will read the boost from the map sensor, then will do a + or - percentage in 1% increments. But 1% difference in an 850 cc injector vs. 1600 cc injector is a lot. Also a T-04S at 1.0 boost vs. stock twins at 1.0 boost is MUCH different. It would adjust to what it thinks are the stock injectors and stock turbo's.
Old Apr 2, 2002 | 10:05 PM
i just wanted to know if i could use the apexi s-afc or if i had to go with a AEM or haltech, o and are the injectors
a drop in.
Old Apr 3, 2002 | 12:34 AM
amemiya's Avatar
since it is a 89 you have high impedance injectors so you will have to stick with high impedance. the question is can the afc go negitive enough to use the 1600cc? I can't answer that I have never tried it. If it will work you will never pull all the power out of it without the AEM. Ok Ok or haltech
Old Apr 3, 2002 | 08:09 AM
Dragon's Avatar
20B N/A Wide Body FC3S
a 10 ohm resistor, about $0.25, in the power wire of the injector will make it feel the same as a high impedance injector... Now all you need is a computer such as the power FC that will let you adjust injector size...
Also if your going to do a GB I would go to the following link I just found...
http://www.musclemotors.com/mustang/mustang.htm
Click on induction, then scroll down and click on fuel system... wait for the page to load then scroll down to fuel injectors... A set of 8 160#hr injectors are $475 and the site says they will accept pay pal... that comes out to $59.38 ea.. you can't beat that...
Chris
Old Apr 3, 2002 | 09:20 PM
blackscorpio's Avatar
#1 F0RUM TROLL
Are the Bosch 160# injectors drop in? Would I have to make any additional modifications besides adding a resistor to the power line? Im runnin a Apexi power FC
Old Apr 3, 2002 | 10:03 PM
Morbius's Avatar
I am pretty sure you will need a modified fuel rail for the Bosch injectors. You can get them from either SR or K2RD for around 150 I think.
-Morbius
Old Apr 4, 2002 | 08:36 AM
amemiya's Avatar
thanks Chris
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
