do i have everything i need?
Old Mar 30, 2002 | 11:16 PM
rx-7girl's Avatar
post whore queen
ok for this engine swap i think i have everthing here is my list
a haynes manual
4 spark plugs
new plug wires
7 quarts of atf
5 quarts of 5w30 oil (was recomended by haynes so i figure ill stick to it)
automatic tranny filter and gasket
oil pan gasket
lots of wd-40
10 feet of vaccum hose
oil filter
fuel filter
air filter
coolant
and i think that is all i bought for it....i think this list is correct? is there anything that i need to add that im forgetting?
Old Mar 30, 2002 | 11:17 PM
rx-7girl's Avatar
post whore queen
oh and i just bought a brand new metric ratchet set and a metric wrench set
Old Mar 30, 2002 | 11:32 PM
riffraff's Avatar
smog nazi destroyer
stange.. i have never looked at the recomendation in the haynes manual..i wounder why they say 5w30..
everything that i have been told says 20w50
Old Mar 30, 2002 | 11:37 PM
Max7's Avatar
Admitted Sevenaholic
extra hands perhaps?
I think that list about covers is, nothings comes to mind.
Old Mar 31, 2002 | 12:12 AM
V8kilr's Avatar
it all depends on the weather,
i run 5w30 in the winter,
and 50 weight racing oil in the summer
Old Mar 31, 2002 | 01:46 AM
Felix Wankel's Avatar
Super Newbie
Belts and radiator hoses.
Old Mar 31, 2002 | 07:10 AM
inittab's Avatar
I read your email
Beer! Ya forgot the beer. More the better.
Old Mar 31, 2002 | 07:23 AM
rx-7girl's Avatar
post whore queen
lol i dont know if i can get my slimy hands on enough beer
Old Mar 31, 2002 | 10:29 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Ok your changing your engine to another used 'running' engine right? Swapping everything from the old block to the new one? If so your gonna need a engine change over gasket set..
On doing the swap :
The old motor is in there right? Just remove the old motor, put them side by side. and start swapping the parts.. Get a full gasket change over kit from Mazda before you do it. Also get a new dizzy cap, rotor button, spark plugs, oil, oil filter, antifreeze, air filter, clutch/pressure plate, throw out bearing, maybe new front and rear seals for the motor since its a used one?.
Guys am i missing anything?
From the other post you made, 'the big moment you have been waiting for or soemthing like that'
Old Mar 31, 2002 | 10:30 AM
MIKE-P-28's Avatar
Id pass on the beer im still hurting from my little stay up 2 days straight and drink every beer I can find extravanganza
Old Mar 31, 2002 | 10:32 AM
peejay's Avatar
Old [Sch|F]ool
Well it depends on what you were drinkin', too...
Last weekend I had my first Budweiser...
All I could think was how much it tasted like cornflakes and water... Sorry Bud, I'll stick with good stuff
Old Mar 31, 2002 | 11:01 AM
rx-7girl's Avatar
post whore queen
hehe ok i got belts and radiator hoses today....jeebus getting all this for the engine is almost costing the engine itself! bbbllllaahhh...i already got gaskets...did you read my list?
Old Mar 31, 2002 | 11:12 AM
peejay's Avatar
Old [Sch|F]ool
do you have a hoist or other means of removing the engine? (i think you can rent them from some parts stores but i'm not sure) How about a floor jack and jack stands?
I prefer to have a vast array of cool power tools and the like, but it can easily be done with simple hand tools. You may want to get some extensions though.
Old Mar 31, 2002 | 11:23 AM
rx-7girl's Avatar
post whore queen
i got all hand tools....and alot of wd-40 im going to rent a cherry picker and have a floor jack i just bought yesterday
anything else you guys can think of?
oh and the radiator hoses were more expensive than i thought!! i was like 20 for both! amazing! anyway if you think of anything else chime me in!
Old Mar 31, 2002 | 11:37 AM
MIKE-P-28's Avatar
All I seen you list were these?
oil pan gasket
If you open the intake/exhaust whatever, your gonna need gaskets from them. Mazda sells a gasket kit, that is a kit that is for the sole purpose to swapping all your stuff over onto a new short block...
Old Mar 31, 2002 | 12:19 PM
hanman's Avatar
You may or may not need them, but be prepared, the motor mounts may not be in good shape.
And you will probably end up buying some odd size metric combo or box end wrenches. There are some different ones like for the oil cooler lines, pulleys, etc.
Very important question: Are you switching an engine from an automatic into an automatic? If not, do you have some way to remove the huge flywheel nut?
hanman
Old Mar 31, 2002 | 01:37 PM
rx-7girl's Avatar
post whore queen
i think it was a manual.this is a new and interesting twist, because i didnt know that there is a huge flywheel nut on the engine? and does that mean i need to trash and remove the flywheel?
Old Mar 31, 2002 | 01:58 PM
Super Newbie
Yes, you will have to remove the 2 1/8 nut on the flywheel and bash it off with a hammer, then put your flexplate/counterweight off the auto engine on the new one.
You'll need some jackstands too. You'll wind up using your floor jack to hold the trans up so you can line it up with the engine.
Old Mar 31, 2002 | 02:00 PM
85rx7blue's Avatar
12a or 13b & what belt #s did u get
Old Mar 31, 2002 | 06:36 PM
rx-7girl's Avatar
post whore queen
i just got the belt for the radiator cuz i know that that is fucked right now...i havent looked under the engine lately to know what other belts i need but got the lower and upper radiator hoses.....
umm got to thinking...once i unbolt the tranny from the old engine is there anything from the old engine that im going to have to move over to the new engine? *where the old tranny was* and if so what will i be looking for and secondly
a big bolt for the flywheel and its just knocking something off? that simple? so i remove the bolt and then proceed to knock something off?
Old Mar 31, 2002 | 06:37 PM
rx-7girl's Avatar
post whore queen
oh and wouldnt whatever im adding to the engine once i knock the flywheel off , not fit? like isnt the engines like made for a specific tranny?
Old Apr 1, 2002 | 08:59 AM
MIKE-P-28's Avatar
On a manual trans car the flywheel and the counterweight are made togther. On an auto theres a counterweight on the E-shaft (where the manual trans flywheel is on the new motor) .
On the new motor you will have to remove the nut and flywheel, and then on your old motor you will have to remove your old flexplate, big ole nut, and the counterweight and put them on the new motor
Old Apr 1, 2002 | 07:50 PM
rx-7girl's Avatar
post whore queen
neato! thanks babes!
