Who has 7 inch wide wheels, I need to know offset.
Old Mar 30, 2002 | 06:12 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
I am going to order wheels but I dont the offset.
They are carbon Konig Blatent 17x7. Custom drilled.
I have a 82 gs.
Thanks
Old Mar 30, 2002 | 08:08 PM
MarkPerez's Avatar
Tennis, anyone
i got 15 x 7 wheels, i don't remember the offset though
Old Mar 30, 2002 | 10:50 PM
thanx, now i can order my wheels with confidence.
Old Mar 30, 2002 | 11:07 PM
V8kilr's Avatar
sounds expensive,
whats the price?
Old Mar 30, 2002 | 11:23 PM
my friend works at a tires plus.
$42 each for yokohama paradas
$67 each for the blatants
$115 custom drilling fee
a tight deal.
Old Mar 30, 2002 | 11:45 PM
Max7's Avatar
Admitted Sevenaholic
Damn thats cheap! going to look sweet!
Old Mar 31, 2002 | 01:25 AM
moremazda's Avatar
Gone Race'n
I have a 28mm offset on 16x7's
Old Mar 31, 2002 | 12:11 PM
Skidrain's Avatar
Do any of you have problems with steering, etc. with those size wheels/offset ratios? Just curious to see what my options are for comfortably fitting, around $500 budget, yet sharp looking rims.
Old Mar 31, 2002 | 01:53 PM
85rx7blue's Avatar
nice
Old Mar 31, 2002 | 03:14 PM
yeah.I have a tornado silver gs. Hear are my exterior plans.
Very dark tinted windows.
Carbon colored wheels (a very dark grey)
V racing wing, aluminum with black end peices
kaminari body kit
All black plastic trim removed
modified rear lights. ( colored parts removed. Painted and tinted so they are similar to the j spec 3rd gen lights.)
Old Mar 31, 2002 | 03:21 PM
Here is the link for the picture of the wheels Im getting
konig blatent carbons
Old Mar 31, 2002 | 04:21 PM
OtakuRX's Avatar
The Rotorheaded Geek
SW33T wheels. Man, now I am going to have to save up and buy me a set of nice rims to replace my 14's.
Old Mar 31, 2002 | 04:44 PM
riffraff's Avatar
smog nazi destroyer
nice wheels 82streetracer.
do you have any pictures of your taillights.. i was thinking about doing something similiar to the ones on my 79
Old Mar 31, 2002 | 06:37 PM
I am in the process of making them right now.
heres how I am doing it. I put the lights in hot water to seperate them. I removed the colored sections. using some special adheasive that easily comes off, I put down some circles on the insides of the lights and sprayed glossy black paint. When I the piant dried. I removed the paper circles i layed in dark tinting film.
The reverse light is very lightly tinted and is still square but know has blue bulbs.
the brake/tail lights are round circles with red bulbs
and the turn signal are oval around the bend and have amber bulbs but I am thinking of making them blue also.
Old Mar 31, 2002 | 06:42 PM
MarkPerez's Avatar
Tennis, anyone
this is off subject but, i have done a templete for 1st
gen tail lights, so it's the same,but it's 2 round circles
for the red lens,1 circle for turn lens, 1 small for back up
so i guess it will look like maybe a 3rd gen's 1996 i think.
the outside piece thats clear,stays clear too,even
thought about colouring the tail lights the same colour
as the car,,in the picture,,,this is just an idea,,i'm not going with it though,,just an idea
Old Mar 31, 2002 | 06:52 PM
I am still looking for peoples offsets.
28 sounds good.
offset is measured from the hub to the centerline of the wheel, right.
Im thinking I need somethink between 25 and 30mm.
I want the side of the tire to be fairly close to the edge of the wheel well
Old Mar 31, 2002 | 07:39 PM
V8kilr's Avatar
i still need to replace my 13's
Old May 27, 2006 | 03:19 PM
wecycle's Avatar
12A wheel offset
It appears to me that the offset to give the best clearance from both the strut and the fender lip would be 12mm.
Old May 28, 2006 | 07:50 AM
$100T2's Avatar
On the prowl for an FB
a tight deal.
Is the custom drilling fee total, or per wheel?
Old May 28, 2006 | 08:04 AM
Buffumguy1's Avatar
I just ordered some Konig Reason wheels. I ended up with a set of 16x7 with a 38 mm offset. I used the 205/45 R16 over the 205/50 R16 tires based on comments from this board. Back in the late 1990's Sport Compact Car Mag. did a 1st gen build up. They removed the springs and mounted a set of 16x7 with a 40 mm offset and had no contact with any parts of the car at any stearing angle and any config of suspension travel. I did'nt figure 2mm was much different. The Sport Compact car did have a rolled inner-fender lip on the front.
Old May 28, 2006 | 09:22 PM
Phiber Optik's Avatar
V8 RX-7
17x7" 40mm offset on an SE
fits perfectly no rubbing with 205-40 front and 225-45 rear
looks good too
Old May 28, 2006 | 09:34 PM
steve84GS TII's Avatar
FB+FC=F-ME
15X7 Centerlines with 205/50-15 Toyos on GSL brakes/suspension.It fit just fine and didnt rub at all with 12MM of positive offset(deepdish).......
After swapping to GSL-SE brakes,I had to roll the fender lips since it pushed the wheels out a bit more.It still worked well,but rubbed ocassionally.The SE's brakes/hubs are more like the FC's and modern FWD cars,it requires much less deepdish and more negative offset to clear the fenders.
Old May 28, 2006 | 10:22 PM
85rotarypower's Avatar
love the braaaap
Well, the Kosei K1's tire rack used to sell were 15x7 and were -17mm offset I believe. A lot a people say they fit without a problem. Your wheels should be fine in that offset as well. This is for a non-SE though.
tonka_1956
Sep 2, 2015 05:55 PM
MILOS7
Aug 19, 2015 07:25 AM
