Power Steering relocation write up.
Old Jun 21, 2007 | 10:08 PM
PoderRotativo's Avatar
Hi everyone!!! After 3 years of being member of this forum. And Learned everything I now from it. I can give something back.
After having some many issues with my new setup I thought that the only way to be able to finish it was to de-power my P/S. A few days ago I so a picture posted by BoostingmyS5 where he relocate the P/S by using the RX-7 84-85 P/S Bracket.
So these are the tools that I used:
2” Cut-off wheel
Hand Saw
File .
As you can see in the pic above the 1st gen p/s bracket will not fit with the 2nd gen. p/s pump. You will have to cut to make it fit. This the most time consuming part since the 2” cut off wheel cannot go that deep since I don’t have a plasma cutter I had to use a standard hand saw.
Now that you cut the excess of material you should have enough room for the pump, but you are not done yet on the pic you will see a blue circle which is an opening for the end piece were the p/s pulley is bolted on. The 1st gen p/s pump seems to be mm. smaller in diameter the 2nd gen, so my pump (yours probably ) will not fit. Since my dremel got stolen I had to make this diameter bigger by using one of those metal file to shave down those mm. If you have a dramel this will be easy.
Now that you have done all these the bracket bolts right on were the old one used to be. And this is how it should look like (sorry for the crappy pics I will take better if need them)
And this is my engine bay if someone its interested why I did what I did.
Ok I hope this is helpful for someone doing something like this. I'm not master fabricator or certify mechanic so please don’t be so harsh. Everything that I know and done its by info provided by this forum.
Old Jun 22, 2007 | 12:38 PM
I will post belt size later
Old Jun 22, 2007 | 12:49 PM
classicauto's Avatar
Crash Auto?Fix Auto.
Very nice!
Too bad I already routed my i/c piping udner the stock pump location
Any pics before the intercooler was mounted? And does the belt ride on the main pulley at the A/C pulley or the steering pulley after re-location?
Old Jun 22, 2007 | 01:09 PM
belt will ride on the main pulley, adjusting p/s pulley and P/S pulley. I dont know how will it work with the A/C since I took it out long time ago that I dont even remember where was it located.
I should take some pics over the weekend
Old Jun 22, 2007 | 10:01 PM
pistones's Avatar
hey dude you posted your set-up. it's not a surprise anymore! i'll see you soon.
Old Jun 23, 2007 | 10:40 AM
lol Yeah stop by this weekend
Old Jun 25, 2007 | 07:36 PM
Ok so I found the right belt to get to work. I got it at strauss discount auto is an automotive v-belt 33013.
Good luck.
Old Jun 18, 2008 | 04:52 PM
NCDA's Avatar
I'm doing this same thing right now. Were you able to use the stock powersteering lines that go from the pump to the rack? Or did you have to source new lines??
Old Jun 18, 2008 | 09:39 PM
you can use the old lines good luck
Old Jun 18, 2008 | 10:59 PM
DragonRx7's Avatar
Goes *round*round*round*
I used this write up as the basis for my own write up last year. I used the aluminum AC/PS bracket available on FCs though. The aluminum makes it easier to cut and work with.
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/how-power-steering-relocation-705539/
Old Aug 1, 2008 | 12:26 AM
drftwerks's Avatar
ima bring this back, does the bracket need to be from a 13b? or is 12a ok?
thanks
Bryon
Old Aug 1, 2008 | 02:27 PM
YaNi's Avatar
RIP Mark
It needs to be a 13B, hence 84-85. The 12A is quite a bit different.
Skeese
65
Mar 28, 2017 03:30 PM
LMBTG
Sep 2, 2015 07:01 PM
c0rpse
Aug 25, 2015 11:50 PM
