Sponsored by: CARiD
quick question about my 1st gen
Old Jun 19, 2007 | 08:35 PM
85RexGSL's Avatar
whenever im racing or revving my motor up to higher rpm maybe 5-6k when i shift or let of the throttle it backfires once then decels fine to about 1500-2k it pops and crackles til it idles,is this normal for rotary engines?or if theres something wrong id like to know! thanx
Old Jun 19, 2007 | 08:54 PM
diabolical1's Avatar
what exhaust configuration are you running?
Old Jun 20, 2007 | 04:59 PM
85RexGSL's Avatar
stock with empty cats,it did it before i hollowed them out too if it should make a difference
Old Jun 20, 2007 | 09:22 PM
Sgt.Stinkfist's Avatar
premix, for f's sake
there is probably an exhaust leak some where letting air in on decel. my car will shoot flames occasionally after i get the exhaust nice and hot, mostly b/c my carb is tuned pig rich at the moment, but it doesn't really ever back fire
Old Jun 21, 2007 | 05:54 PM
air is getting in there somewhere - holes or broken welds.
Old Jun 21, 2007 | 11:52 PM
85RexGSL's Avatar
alright.i had already replaced about 4 exhaust gaskets but i guess theres more work to be done! thanx guys!!
Old Jun 22, 2007 | 02:45 AM
PercentSevenC's Avatar
I need a new user title
Misfiring at low RPM when returning to idle seems fairly normal for older-style rotaries (particularly so for ported ones). Is that what you're referring to? Either way, you obviously have exhaust leaks.
Old Jun 23, 2007 | 01:15 AM
85RexGSL's Avatar
well as far as i know i was by the previous owner it was ported,who had bought the motor with around 58k miles on it from a wrecking yard so yea another reason i think its ported cause i get worse mpg than my friends stock fb....im getting around 13-14mpg,sound right to u? im somewhat a rotary noob being my first rex and all.so im trying to figure it all out.
Boriquaguerrero
20
Apr 22, 2019 01:15 PM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
craaaazzy
Comments and Suggestions Archive
Aug 21, 2015 02:00 PM
Marty RE
Aug 13, 2015 11:19 AM
