Megasquirt zems questions
Old Jun 12, 2007 | 10:47 AM
bebiracer's Avatar
zems questions
well im buyin a zems from the second batch and wanted to know wat are the differences in both batches..?
will there be in any way possible to get software to control the zems on a handheld palm?? i mean the lap top is hot but wen ur on the road i would like somthin small to monitor it and change things..
thats about it thanx guys
Old Jun 12, 2007 | 10:55 AM
muythaibxr's Avatar
MegaSquirt Mod
The second batch uses our own design for the daughtercard and changes the adapter from a wire-adapter to a board.
If you can use a palm on a normal megasquirt running ms1/extra, then you can do it on the zems.
Ken
Old Jun 12, 2007 | 11:04 AM
bebiracer's Avatar
well how will i be using it? can i install the software to adjust a megasquirt on a palm and if so how and where can i get it
Old Jun 12, 2007 | 12:53 PM
muythaibxr's Avatar
MegaSquirt Mod
I don't know. We have never used the palm software. I know software exists, and that's about it.
Old Jun 12, 2007 | 01:07 PM
bebiracer's Avatar
oh ok do u think on the diy.com site they might know or have it ?? thanx for the info by the way u guys give more support than other standalone companies dude thanx
Old Jun 12, 2007 | 02:56 PM
muythaibxr's Avatar
MegaSquirt Mod
I think renns wrote the software, or you could check over at msefi.com
They have a section for the palm software... I think the palm software may be for datalogging only, I don't know if it's capable of changing settings or not.
Ken
Old Jun 21, 2007 | 10:16 AM
grendel_2000's Avatar
meat popsicle
Does the megaview work with the megasquirt n spark? if so that could be an option.
Old Jun 21, 2007 | 10:47 AM
renns's Avatar
PalmTune allows VE table editing on MS1 codes. PalmLog displays and datalogs runtime data for MS1 and MS2. PalmEdit allows editing of any MS1 config setting. See the Palm Software area on msefi.com for more info.
Old Jun 21, 2007 | 08:07 PM
bebiracer's Avatar
i got the a zames from the secon bath and was wondering wat verision of ms is it and all that im trying to set up my palm so i can use it
Old Jun 21, 2007 | 08:09 PM
bebiracer's Avatar
zema im sorry lol
Old Jun 22, 2007 | 05:37 PM
muythaibxr's Avatar
MegaSquirt Mod
it depends on which run of zems units it came from...
In any case, you should flash 029w onto it, and tune using that.
Ken
Old Jun 25, 2007 | 02:34 PM
bebiracer's Avatar
thanx for answering my questions i got another ive been looking for it but can u point me in the right direction on rewiring the fuel pump to zems?? do i have to solder anything?
Old Jun 26, 2007 | 09:31 AM
muythaibxr's Avatar
MegaSquirt Mod
From the second batch, there is a hole on the adapter board labeled "FP"
The easiest thing to do is wire that to the "fuel pump test connector"
You will have to solder the wire to the board.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
