Power FC Power FC Boost Control
Old Jun 8, 2007 | 01:44 PM
93RedDragonFD's Avatar
I know that the Power FC has a seperate Boost Controle Kit, but i was wondering if it controled boost on its own (with commander) or is a seperate EBC or the PFC Boost Controle kit need to control boost levels up and down..?? Anyone know?
Old Jun 8, 2007 | 03:02 PM
ermin277's Avatar
It can control the stock WG control solenoid if you still have it hooked up and working (just like the stock ecu did). The "kit" can be used if you go single, as it provides a apexi WG control solenoid.
-spence
Old Jun 8, 2007 | 05:15 PM
I currently am running my stock twins, but if i decided to go single later on i would need the kit or some other sort of EBC right?
Old Jun 9, 2007 | 12:56 AM
batmuk's Avatar
nah your apexi boost controller kit and commander is all you will need to control your boost,single or twin.
Old Jun 11, 2007 | 03:44 PM
RotaryEvolution's Avatar
Sharp Claws
correct
Old Jun 29, 2007 | 12:23 AM
Thanks Guys!
Old Nov 9, 2007 | 05:22 PM
MADDSLOW's Avatar
17 second FD
Sorry to bring this thread back up from the dead, but I am currently looking at an Apexi boost controller that I *believe* plugs right into the PFC. How good of a boost controller is this unit? I was contemplating purchasing a Profec-B Type-S, but if this will do the job just as well, I'm all about it. My stock solenoids just aren't cutting it
Input, please! Thank you! ~A-Rod
Old Nov 19, 2007 | 04:16 AM
RX7LINK's Avatar
RX7FD3S
I have the boost kit. It works just as well as a profec-B or any other simple EBC. Probably don't have the offset function like more expensive EBCs.
it comes with:
- a new Denso 3 bar map sensor. direct replacement of the stock one
- new solenoid (same as the one used in avc-r)
- plugs&wires to hook up the solenoid and stock map sensor to the PFC unit.
what it does is it uses the new solenoid, which you setup the same way as a regular boost controller, and the PFC only reads the 'primary' setting on the Commander to determin desired boost level. whether you're running sequential, parallel, single. The PFC takes readings from the 3 bar and compare it to the stock map sensor.
Old Jul 31, 2009 | 07:24 AM
revhardallday's Avatar
Bang Bang!
Im currently single turbo and i would like to purchase this boost controler kit.
Any one know who sells them?
Old Jul 31, 2009 | 10:54 AM
arghx's Avatar
rotorhead
if you have a Datalogit you don't need the boost control kit. you can use the stock wastegate solenoid by keeping "sequential turbo control enabled" and making some minor plumbing changes.
Datalogit settings
full thread here: https://www.rx7club.com/3rd-generation-specific-1993-2002-16/free-power-fc-single-turbo-probably-nonsequential-boost-control-846883/ Use the plumbing I posted here, the ones in the beginning of that thread are correct but somewhat misleading due to the way I had my solenoid mounted.
Old Aug 9, 2009 | 12:15 PM
plutten's Avatar
Out of rubber
Is it possible to have different boost pressure on different rpm using "turbo transition"
I have a single turbo and would like to limit my boost under 5000rpm
Old Aug 10, 2009 | 12:58 AM
arghx's Avatar
rotorhead
Sort of. By controlling boost with a factory boost control solenoid and sequential turbo control enabled, setting turbo transition high to 5000 would effectively run you at spring pressure until then. That's not so precise, and I can see you getting frustrated with it. You may want to consider an AVC-R, it'll do a lot better job for what you are looking to do as long as you set it up right.
Old Aug 10, 2009 | 01:39 PM
plutten's Avatar
Out of rubber
Yeah thats what i thougt and using only spring pressure from the beginning will be slow in building pressure..
MoTeC
Sep 10, 2015 07:58 PM
