new clutch master, but cant pressurize system?
Old Mar 28, 2002 | 09:40 PM
hurleyboi514's Avatar
Thumbs down new clutch master, but cant pressurize system?
my hydraulics on my clutch went bad, so i couldnt change gears. i rebuilt the slave and replaced the seal, and i got a new master. but now, i cant get the clutch to work properly. ive gone through 2 quarts of fluid trying to get them pressurized. the pedal just hits the floor and stays down. what should i do? and how should i do it? to bleed it, ive been opening the valve, pressing the pedal, shutting the valve, lifting the pedal, and so on over and over. then i tried pushing the pedal, and opening and shutting the valve, then lifting the pedal, but that didnt help either. any ideas?
Old Mar 28, 2002 | 09:43 PM
SpeedRacer's Avatar
Formula Mazda Driver
I'm guessing you bench bled the cylinder first?
Old Mar 28, 2002 | 09:50 PM
no, never heard of of it.... it wasnt in my haynes manual...
Old Mar 28, 2002 | 09:56 PM
vosko's Avatar
Just Call Me Terminator!
i just changed mine on my TII yesterday. all we did was put it on then bleed it. i did have to pull the pedal off the floor a few times.
Old Mar 28, 2002 | 10:00 PM
man....
i wish i could say the same...
Old Mar 28, 2002 | 10:06 PM
vosko's Avatar
did you check the clutch hose ? make sure its not ripped or leaking ?
Old Mar 28, 2002 | 10:08 PM
Six Rotors's Avatar
Assuming you still have the M/C in the car,crack the hydraulic fluid pipe at the M/C so that air/fluid will leak out,put a rag or something around it to stop the fluid going on your paint,pump it a couple of times to get all the air out of the M/C,tighten up the joint,then bleed at the slave bleeder.
Old Mar 28, 2002 | 10:09 PM
Rpeck's Avatar
What R U thinking self?
Bench bleed the master cylinder first with some back pressure. Use your finger to create back pressure. pump the clutch 5-10 times... hold down, open valve ... do that till you get some pressure built up, then do it one pump at a time. Hold clutch down open valve... close valve, release clutch.
Gotta have back pressure to start it all though.
Old Mar 28, 2002 | 10:16 PM
wait, what do i put my finger over? do i put the cap on when im bleedin the system?
Old Mar 28, 2002 | 10:44 PM
Rpeck's Avatar
um hook the fluid pipe/hose athe the closest spot to the M/C plug that with you finger off and on to bleed the M/C and create back pressure.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
alphawolff
Nov 17, 2015 05:57 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
