How much $ for a pressure sensor?
Old Mar 28, 2002 | 10:06 AM
Samps's Avatar
I need a new pressure sensor and I can't seem to find one. Where can I get one? And about how much is it gonna cost me? I'd rather not get a junk yard special.
91 NA
Old Mar 28, 2002 | 10:15 AM
J-Rat's Avatar
Alcohol Fueled!
I may be able to get them through Checker Auto Parts. I can price it and then I get an additional 25% off since I am an employee. Hold on, and I will get you a price.
Rat
Old Mar 28, 2002 | 10:16 AM
J-Rat's Avatar
Alcohol Fueled!
Is it the atmospheric pressure sensor?
Old Mar 28, 2002 | 10:17 AM
blu_gxl's Avatar
you can go to hypnitiz7(sp?) i know that's not how you spell it but he has a web sales preasure sensors for around 25 plus shipping all tested good also. i was thinking of buying one from him but did not need to, also if you want to pm me i have another guy who i get parts don't know if he will have that part but you can try. still hypnitiz7(SP?) will be your best bet for that part
james
Old Mar 28, 2002 | 10:19 AM
Samps's Avatar
It's actually a Boost pressure sensor on NA's I think, and a Atmospheric pressure sensor on turbo cars. Sounds backwards but I'm preaty sure that's how it is.
J-Rat's Avatar
Alcohol Fueled!
You know what? I emailed hypnitz7 (sp) about some porting work, and he hasnt responded. Is he really busy?
Old Mar 28, 2002 | 10:20 AM
J-Rat's Avatar
Alcohol Fueled!
Is that the proper name for it?
Old Mar 28, 2002 | 10:30 AM
blu_gxl's Avatar
http://hypntyz.rx7life.com/
here is the link to his parts page it's also in his sig
Old Mar 28, 2002 | 10:31 AM
Samps's Avatar
I'm preaty sure it's a "Boost Pressure Sensor" for a 91 NA.
Mine has a reading of 5 volts, according to the manual it should be in between 3.5-4 I believe. I accidently got some carb cleaner in it and ever since it has been acting up. At first I got a check engine code for it (1-3) then that went away. And now I have that damn 3800 rpm hesitation; I have avoided that damn hesitation untill this stupid sensor started acting up. Actually spraying in some of that damn carb cleaner is the root of this problem. I really wish I never used the CC; al least I only used about 1/10 of the can or who knows how many other problems I would have. I may have also blown out the lil pill that is supposed to be in the line. Do NA's have that lil pill? Because after I realized the CC got to the sensor I detached the line and blew through it to clear out all of the CC; but I may have blew out the pill in the process.
blu_gxl's Avatar
don't know if he's busy just saw the preasre sensors on his site while looking for parts one day and they were realy cheap, so i thought i's pass along the info
james
Old Mar 28, 2002 | 10:32 AM
Samps's Avatar
He only has a listing for a series 4
Old Mar 28, 2002 | 10:36 AM
J-Rat's Avatar
Alcohol Fueled!
Yeah, I read the thread about Carb cleaner earlier, saw that it caused you some trouble. Sorry, It looks like I cant get the part. I may have to go into work and do some research on it. Let me know if you find it somewhere else.
Old Mar 28, 2002 | 10:42 AM
Samps's Avatar
I'm gonna call around but if a used one runs $25; a new one probably aint cheap.
Thanks for all the help guys!
Old Mar 28, 2002 | 10:51 AM
Samps's Avatar
I called mazdatrix and they told me that if I am no longer getting the bad pressure sensor code then mine must be fine. I thought that the factory ECU or CPU, which ever one does the diagnostics, was a lil on the iffy side; but if mazdatrix says so then I must believe. My car does not show any codes as of right now, so I wonder what I could of damaged with the CC that would give me that damn hesitation?
Old Mar 28, 2002 | 10:52 AM
Samps's Avatar
Oh yeah a brand new one costs:
$300 freakin dollars! yep; $300 freakin dollars!
Old Mar 28, 2002 | 11:06 AM
Thaniel's Avatar
WHAT!!! $300!!. It's a little sensor. What's it made of GOLD?
Why is it everytime I price parts for this car I feel I'm getting screwed?
Old Mar 28, 2002 | 11:33 AM
Samps's Avatar
Pressure sensor and TPS both run about $300.
Lil plastic diffusers cost like $40
And a ACV costs like $50
You would think we're driving Ferrari's
Old Mar 28, 2002 | 11:35 AM
J-Rat's Avatar
Alcohol Fueled!
****, if you want a new AFM, get ready to shell out $405.00
Old Mar 28, 2002 | 11:36 AM
J-Rat's Avatar
Alcohol Fueled!
Why do you think I have a second job at an auto parts store?
Old Mar 29, 2002 | 11:26 AM
Thaniel's Avatar
Least for the AFM your getting something. The N/A boost sensor isn't anything special.
Old Mar 29, 2002 | 11:29 AM
J-Rat's Avatar
Alcohol Fueled!
True, but you gotta admit. For the money, you aint getting much....
Old Mar 29, 2002 | 12:14 PM
blu_gxl's Avatar
actually if you need a new afm what you do is go to mazda dealer tell them you are having hesitation over 6k rpms. there is a tsb that says for that problem you need to replace the afm with another one from a different part seriers, i love alldata!
james
might not work but worth a shot
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
t-von
Sep 10, 2015 01:56 PM
vmerino
Sep 5, 2015 11:26 AM
