ok, did tb mod, what else can i get rid of
Old Mar 26, 2002 | 08:07 PM
i did the throttle body mod, can i get rid of the bac valve too???????. if so how, and what does it do...........
i am running a completely stock(xcpt tb mod) 87 n/a
BTW i am on a low budget
what else can i get rid of?
Old Mar 26, 2002 | 09:33 PM
I wish I was driving!
You can get rid of BAC if you have no A/C or P/S, but its not worth it really. Do you have cats?
Sean
Old Mar 26, 2002 | 09:58 PM
yes, i do have cats...., anyhow, what does the BAC do, and how....????
Old Mar 26, 2002 | 11:24 PM
zaxfire69's Avatar
Hey guys exactly what is the throttle body mod???How do ya do it??Explain please...86 N/A
Old Mar 27, 2002 | 01:54 PM
Well, with cats, you're pretty limited to what you can remove. Most of the solnoids run into the Air control valve, which regulates the air going from the air pump into the cat. You can not remove them if you have cats, or your cats will burn out and you'll lose power/ or damage your engine.
If you can ditch the cats, do it.
The BAC allows air to move past the closed throttle plates ate idle (b/c some air still has to move past).
If you turn the wheels with p/s, the BAC allows more air past into the engine since more strain is put on the engine from the pump, so it keeps a constant idle. Its the same if your a/c is on at idle. The a/c compressor puts extra strain on the motor, so the BAC gives the engine more air to keep a constant idle.
Without p/s or A/c, you can block off and bypass the BAC, but be prepared for an error code.
Sean Cathcart
Old Mar 27, 2002 | 01:56 PM
This explains all....
http://fc3s-pro.com/TECH/HOWTO/TBM/tbm.html
Sean
Old Mar 27, 2002 | 02:01 PM
blu_gxl's Avatar
you can do the e-fan mod did mine for around 40 dollars including the gas it took me to go all the way to another city to buy the fan, and misc. parts
james
renjiv2
57
Jan 25, 2024 03:34 AM
demetlaw
Oct 2, 2015 06:22 PM
musker
Oct 1, 2015 05:58 PM
