Nelson/Paxton EFI Supercharger System
Old Mar 26, 2002 | 03:40 PM
bcty's Avatar
Boost This!
I know someone on this forum has one of these and i was just wondering about the price and the easy of install... i think that i might go boosted after a lot of thought.. i will build up my n/a to about 250-270 hp and then add one of these... what are your experences with this and what am i lookin at for costs... thank u....
http://2ndgenrx7.freeservers.com/techmaster.html
hopefully i didnt 2x post
Old Mar 26, 2002 | 04:10 PM
vaughnc's Avatar
knowledge junkie
Don't forget you'll need to swap in the TII driveaxel, transmission, & rear differential as the NAs drivetrain is not heavy duty. There may be other parts as well.
I believe roadrunner has one of these on his NA.
Old Mar 26, 2002 | 04:20 PM
KNONFS's Avatar
B O R I C U A
You do not need to replace your drivetrain!!
Old Mar 26, 2002 | 04:42 PM
vaughnc's Avatar
knowledge junkie
Knonfs,
Please do explain I've heard an additional 30-40ft/lbs torque (25% more) is all the NA drivetrain can stand.
-- vaughnc
Old Apr 26, 2006 | 02:28 PM
the.white.fc3s's Avatar
That's it? What else? How much is the supercharger cost?
Old Apr 26, 2006 | 02:57 PM
rotorforce's Avatar
I'm back Bishes
How do you plan on getting your engine to 250-270hp prior to adding a supercharger??
Old Apr 26, 2006 | 05:00 PM
Jager's Avatar
Tear you apart
The rear end is used in 10 second and 11 second V8 swaps. It's fine.
The tranny with a good driver should be plenty fine for up to 300HP if not more.
Old Apr 26, 2006 | 05:03 PM
Jager's Avatar
Tear you apart
Alot since they don't make it anymore .
Old Apr 27, 2006 | 10:04 AM
Aaron Cake's Avatar
Engine, Not Motor
They only made about 10 of these kits because most owners were too cheap to spend the $3K they cost. Your only chance of getting one is finding a used kit for sale.
Old Apr 27, 2006 | 04:12 PM
rotorforce's Avatar
I'm back Bishes
Theres an N/A with that exact supercharger in the for sale section
https://www.rx7club.com/showthread.php?t=525473
Old Apr 27, 2006 | 04:22 PM
Man... awwww...
Old Apr 27, 2006 | 04:41 PM
2fast4ouru's Avatar
This is a great kit, really wakes the car up after 3500 rpm's. It was a moderately hard install. The reason for this is the pulley's that came with mine didnt fit correctly so I had to have them machined to spec. The supercharger fitment was another issue as it is really tight and there is almost no room for clearence. I recomend upgrading all of your old bolts and fittings on your engine, as well as replacing and securing vacuum lines while you install this. Finally, I found mine used for under two grand, which is why I did this instead of a custom turbo install. Good luck!
Old Apr 27, 2006 | 05:13 PM
speed_monkey's Avatar
affen
Im wondering that aswell... I hope you arent planning on a BP or PP... with a supercharger you are going to want to keep overlap as low as possible.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
jim_chung
1st Gen General Discussion
Oct 4, 2015 09:09 AM
Zinraf
Oct 1, 2015 01:09 PM
RuffRx7
Oct 1, 2015 03:08 AM
Turblown
Sep 30, 2015 05:58 PM
