Air Pump shorting out on housing
Old Mar 26, 2002 | 12:23 PM
BigRed's Avatar
I've lost some of the insulation around the wiring on my airpump and it's causing the airpump to stop working when it grounds out against the metal housing. Other than a good electrical tape job, has anyone come up with an efficient cost-effective solution?
Thanks
Greg
Old Mar 26, 2002 | 06:45 PM
Swamp RX-7's Avatar
From what I've learned, the airpump is turned on when it grounds, it always has power running to it, when the ECU tells the relay to close, it grounds the air pump.
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
4sfeedit
Aug 16, 2015 01:42 PM
