FC Oil Cooler/Radiator Ducting
Old May 11, 2007 | 09:30 AM
dbgeek's Avatar
Happy Squirter
I had a blast at CMP this past weekend, but the oil temps were too high. I've read to duct the oil cooler and radiator, but have not seen any pictures of effective ducting. I'd like to do this to my car, but want to make sure I do it correctly. I've heard to use aluminum, but ABS plastic is also readily available and lightweight.
Does anyone have pictures of their engine cooling duct-work? Is there a preference for material? How are you sealing the duct-work to the oil cooler and radiator?
Thanks
Pete
86 Sport with 89 engine - Megasquirted.
Interior comes out this weekend for 6-point cage install- Woohoo
Old May 11, 2007 | 10:57 AM
j9fd3s's Avatar
Community Builder
water temp in these cars is pretty simple, its a function of radiator size, and how well its sealed to the body.
oil temps are different, the oil cooler in the stock setup doesnt get the greatest airflow. ducting more air to the oil cooler really lowers temps. ive seen fans, flaps (think 80s GM, works well!!)and better sealing around the cooler.
it also seems like getting the hot air OUT at some point is important....
Old May 11, 2007 | 11:52 AM
RX-Heven's Avatar
I'll blow it up real good
My oil cooler setup and ducting.
https://www.rx7club.com/forum/showpo...4&postcount=22
I have a big fmic but I still provide the oil cooler with its own dedicated fresh air supply that you ca see below the ic. I also have a vented hood that helps.
Old May 11, 2007 | 12:06 PM
gracer7-rx7's Avatar
needs more track time
I think Crispy had a few pics of his oil cooler setup and ducting for his ITS FC.
https://www.rx7club.com/showthread.p...ght=oil+cooler
Actually, now that I searched I found a lot of threads on this.
Old May 11, 2007 | 12:41 PM
dbgeek's Avatar
Happy Squirter
Thanks guys - I had found Crispy's posts, but they were more toward setting up dual oil coolers. I've found a ton of info that says you have to duct it, but have found very few posts with pictures showing HOW you did it.
Dave - excellent pictures, this is what I'm looking for, Thanks!
Old May 11, 2007 | 12:48 PM
wrankin's Avatar
Old Rotary Dog
There are quite a few threads. Most involve adding a second stock cooler.
Crispy has a more detailed writeup on his second oil cooler installation on his site:
http://www.negative-camber.org/crisp...c/fcpart28.htm
Ducting is definitely a key part - especially on the sides. Make sure that all the air going into the front of the car makes it to a radiator.
My second cooler actually sits behind the front bumber and is ducted via a couple cutouts in the nose. It vents over the top of the radiator, so it uses a completely isolated air path. It is similar to Lemon's E-Prod convertible:
http://www.mazdatrix.com/faq/epconv.htm
You may also want to go over to www.improvedtouring.com and do a search for "oil cooler" in the Mazda-specific section of their forum. Specificaly:
http://itforum.improvedtouring.com/f...&hl=oil+cooler
Hope this helps,
-bill
Old May 11, 2007 | 02:24 PM
engled's Avatar
Cone? What cone?
Check out alanb's set up, he seems to think he has his cooling issues fixed.
http://www.pbase.com/speedmonkey/new_cooling_system
Old May 11, 2007 | 03:04 PM
dbgeek's Avatar
Happy Squirter
Great links Bill - thanks. The ITForums link has an excellent detailed explaination of the duct-work, and also has a great discussion of different cooling methods.
Does that Mazdatrix car have all frontal air going through the two oil coolers? I would think you'd want to divide the incoming air between the radiator and oil cooler?
I have read Crispy's FC build several times, and have to thank him for detailing everything he's gone through, as I have referenced those pages more than I'd care to admit
Old May 11, 2007 | 05:22 PM
SCCAITS's Avatar
SCCAEP
Aluminum tape, aluminum sheet, aluminum 1" strip, pop rivets, some SS bolts. It works and fixed my cooling issues. I'm going to re-do it when I get a weekend with thicker alumimum and make it easier to remove similar to RX-Heven setup. You'll need a lift when doing the fabrication to make things much easier.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
