Sponsored by: CARiD
Counterweights-what's the difference?
Old May 9, 2007 | 10:09 AM
3rd-Gen-Rcr's Avatar
Can anyone tell me the difference between these two counterweights? And which you would use with an aftermarket, lightweight flyweel. (93 5sp)
Thanks
Attached Thumbnails Counterweights-what's the difference?-counterweight.jpg   Counterweights-what's the difference?-counterweight2.jpg   Counterweights-what's the difference?-counterweights.jpg
Old May 9, 2007 | 12:43 PM
Noxlupus's Avatar
The ones that I would suspect you would want to use is the center one (The right one on the last picture). That one looks like the one that I got with my XACT ProLite flywheel.
But I could be wrong, I'm only going by looks.
Old May 9, 2007 | 06:14 PM
Yeah I think you're right. I haven't seen any pictures of flywheels with the smaller weight attatched. Figures someone sold me the smaller one on the left for a 93> flywheel.
Anybody else know for sure? Or what the smaller flywheel is even for?
Old May 9, 2007 | 07:43 PM
n1ray's Avatar
Your engine has 2 counterweights in it, one at the back (flywheel) and one at the front of the engine. The smaller one goes at the front and the one with 6 holes is for flywheel. You have to make sure the front and rear are a matching pair and that its the correct weight pair for your year model 13b. Do a search and you'll find part number - year model references.
Old May 10, 2007 | 09:01 AM
Oh ok. That sounds somewhat logical. Where, on the front of the engine does the smaller one go?
Old May 10, 2007 | 05:39 PM
n1ray's Avatar
Inside the front timing cover stack, just behind the drive gear and chain for the oil pump. If the counterweights are correct for your engine then the front weights will be the same and no need to change it.
Old May 11, 2007 | 11:31 AM
Very good, thanks for the info.
Old May 17, 2007 | 10:33 PM
slpin's Avatar
7th Heaven
yeah
if you have to change the front counterweight to a different weight one too, you have to change the rotors to match that
Old May 19, 2007 | 06:57 PM
trochoid's Avatar
Old Fart Young at Heart
If you want to see where the front counterweight goes, download the FSM for your year that's listed in my sig line.
Old Jul 18, 2007 | 12:39 AM
joe-c's Avatar
YOUR MOM IS MY ADDICTION
Veteran: Navy
glad to see someone knows wat they are doin thats y i always turn to the searches in da forums
Shainiac
Jul 17, 2019 02:20 PM
Spirit Rx-7
Mar 14, 2016 12:36 PM
Captain Hook
Sep 22, 2015 01:12 PM
Ian_D
Sep 6, 2015 10:38 PM
