whats wrong with my 93 rx7 ?
Old Mar 25, 2002 | 06:14 PM
jayrx7's Avatar
Newbie
i own a 93 rx7 with 34k miles on it. the car is completely stock and the past week its been giving me problems. when i start it up the car will shake very noticable and sounds like its missing bad. then when im driving the car it will hesitate and jerk alot once i go over 3k rpms. now my coolant light just came on i havent driven it since. any suggestion would help please.
Old Mar 25, 2002 | 06:20 PM
Call 911's Avatar
Change the plugs and add coolant. I don't think the problems are related. IMO
Old Mar 25, 2002 | 06:51 PM
PureMdMa's Avatar
1 of 203 94 White PEP's
Check the fuel filter and the plugs and wires also you might want to try reseting the ecu.
Jeremy
Old Mar 25, 2002 | 07:48 PM
funnyguy_11's Avatar
Check the oil for coolant, change the plugs, and check the wires, and hopefully it will rule out those problems. It sounds electical to me. Listen to PureMdMa and reset the ecu. My last car, a Grand Am, did the same thing. It had a slight leak in the head gasket which leaked coolant into the combustion chamber. This only cause some problems at ideal and on start up. Once the head gasket went, it only lasted half a day. That's when I bought my 7.
Old Mar 25, 2002 | 07:49 PM
rynberg's Avatar
Check to see if the hose running from the MAP sensor to the throttle body is still attached at both ends. It typically blows off the MAP sensor end. The MAP sensor is little box supported off the firewall by the intake elbow and master cylinder. If the hose is disconnected, reconnect and reset the ecu. To reset ecu: unplug neg batt cable, hold brakes for 30 seconds, reconnect batt cable and start. Hopefully this solves your shaky, hesitating problem.
Coolant light: not to be a total smart ***, but did you check your coolant level? It doesn't say so in your post.
Old Mar 26, 2002 | 06:48 AM
jayrx7's Avatar
Newbie
thanks for all the in info all be getting it looked at today
Old Mar 26, 2002 | 11:08 AM
The Sloth
How does pressing the brake while the battery is disconnected effect resetting the ECU?
Old Mar 26, 2002 | 11:14 AM
rynberg's Avatar
That's just the procedure Mazda uses to reset the ecu. It's just Ctr-Alt-Del on a computer.
Daua118
SE RX-7 Forum
Dec 5, 2021 04:15 PM
wstrohm
3rd Gen General Discussion
40
Apr 16, 2016 08:23 AM
MazdaAspec
Sep 9, 2015 02:04 PM
