Wastegate pill thing
Old May 7, 2007 | 06:28 PM
RX7 NOOB's Avatar
Ok so I've been tring to fix my boost leak for almost a month (checked all hoses, installed efini y-pipe), so I had no primary boost untill today when I replaced the c- clip on the actuator rod. And now I'm getting boost but only 6 psi at WOT . So I read up on pills in the wastegate, and pre turbo control actuator hoses so I opened them up and the wastegate hose does'nt have a pill and the pre control does. How do you think the pill just dissapears? Is this most likely the problem, and how should I fix it?
wastegate actuator and hose w/ no pill
Precontol hose with pill
Please delete my last thread (stupid computer)
Old May 7, 2007 | 07:34 PM
HKNY's Avatar
Thou Shall Search
just get a new pill,do a search to find out what Carb jet is the right diameter for you.I think the dealer only sells the pills with the hoses from what i remember.
Old May 7, 2007 | 07:43 PM
dgeesaman's Avatar
You're on the right track, as long as there is no boost controller being used besides the stock wg solenod.
It's not hard to buy a used wg pill for a few dollars.
The size of the stock pills are on www.fd3s.net so if you can buy the same size carb jet instead if you'd prefer.
Before buying anything though, I'd make sure there is no orifice built into the nipple on the turbos. If you can easily run a paper clip wire through that nipple, then you should buy a pill.
Dave
Old May 7, 2007 | 08:14 PM
RX7 NOOB's Avatar
I need 0.064. Can I find these carb jets at Autozone or Napa?
Old May 8, 2007 | 05:31 AM
dgeesaman's Avatar
I had to go to the local domestic speed shop.
If you can't get them locally, just put a WTB in the classifieds.
Dave
Old May 8, 2007 | 09:33 AM
adam c's Avatar
Cheap Bastard
If your car is stock, the stock wastegate pill will be fine. If your car has been modified, and has a stock ecu, you may overboost with a stock pill. What mods (if any) have you done besides the y-pipe?
Old May 8, 2007 | 11:12 AM
RX7 NOOB's Avatar
intake, dp, hfcat, catback, rx7.com chipped ecu
Old May 8, 2007 | 03:13 PM
adam c's Avatar
Cheap Bastard
Rather than installing a pill, I suggest that you install a needle valve boost controller. That way you can set the boost where you want. You can make one for less than $10.
http://www.robrobinette.com/boost_controller.htm
Leave your prespool line stock. Do not install a valve on the prespool line!!!!
Old May 8, 2007 | 07:09 PM
HKNY's Avatar
Thou Shall Search
http://www.boostcontroller.com
Old May 8, 2007 | 07:22 PM
RX7 NOOB's Avatar
will 13 psi be safe if I replace the stock intercooler
Old May 8, 2007 | 07:42 PM
HKNY's Avatar
Thou Shall Search
what other mods do you have? You just cant bump up the boost up to 13psi without having the proper supporting mods.
Old May 8, 2007 | 08:28 PM
RX7 NOOB's Avatar
Old May 8, 2007 | 09:07 PM
dgeesaman's Avatar
That's pushing the limits of stock injectors further than I would go. To be safe, 12psi is what I would run a chipped ECU regardless of what boost it says it supports.
But installing a boost controller (manual or electronic) is another really good option.
Dave
13
Jan 9, 2018 11:19 AM
jsesq
27
Sep 25, 2015 11:10 AM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
