aquamist tuning configuration
Old May 7, 2007 | 02:46 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
assuming you do not wish to mimic the injector duty cycle and want the spray to start at X psi and then wish to manually set the levels of injectant...
using either the 2C-D-S or the new offering what do you use? a laptop? is there an X and Y grid? if so how many cells? i searched the website and was unable to find the answer and the AQ forum is currently down.
TIA
hc
Old May 7, 2007 | 03:01 PM
PimpyHand's Avatar
Only the 2s system will do as you ask. Its programable for PSI (including cut in) and % of injection per 1k RPM.
Full 3D maping (presure vrs RPM)
Old May 7, 2007 | 05:14 PM
does the 2s have a graph w an X and Y axis. if so how many cells? is it accessed thru a laptop?
hc
Old May 9, 2007 | 09:58 AM
SilentRun7's Avatar
If it does allow control through the use of a laptop, then it would be nice.
However, I intend to modulate the output of both the HSF-5 systems that were recently purchased via each car's ems.
The excellent quality high speed valve (HSV) that Aquamist employs is ideal for this purpose, and the ems allows full 3d control, just like an injector.
Old Jun 21, 2007 | 02:34 PM
calculon's Avatar
On flats
Have you done this yet SilentRun? I'm gonna try the same thing using my e11v2, and would like any pointers I can get
Thanks
ryan
Old Jun 25, 2007 | 07:07 PM
cozmo kraemer's Avatar
Darkside FD
can you do it with one of the aux in-out s of the datalogit on the PFC?
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
