Installing stationary gear bearings
Old May 4, 2007 | 12:59 PM
Speedworks's Avatar
Pineapple has a great vid about insalling the rotor bearings. The stationary gears also seem to need a trick to align one of the bearing holes with the screw hole.
It's not that hard to do but maybe there is a simple trick to get it right the first time.
Thx
Old May 4, 2007 | 08:46 PM
jgrewe's Avatar
GET OFF MY LAWN
Mark the bearing with a sharpy with a line along the edge lined up with the hole. Then mark the stat gear to show where the screw is and line them up and shove them together.
Old May 17, 2007 | 03:07 PM
Speedworks's Avatar
does the housing need lubrication before pressing them in or is it better dry-dry?
Old May 17, 2007 | 04:59 PM
C. Ludwig's Avatar
www.lms-efi.com
You want them clean and dry. Any lube will promote spinning of the bearing in the gear. Freeze the bearing before you install it and it'll slide right in.
Old May 17, 2007 | 05:18 PM
crispeed's Avatar
'Tuna'
Also slight warming of the rotor/stationary gear also helps.
Alpine
Microtech
Sep 5, 2015 09:42 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
