IHI RHC7 .. opinions?
Old May 2, 2007 | 01:16 AM
Ottoman's Avatar
always modding
I found this turbo for sale from a local guy.. it was originally intended for a skyline GT-R... but was never used
I'm thinking of using it for my stock port FD as a good responding street turbo
it's supposed to be good for ~600 hp
i can't find much info about this turbo tho... even the IHI website is weak...
it's a T4 flange.. 0.78 A/R in the back...
the guy wants $550 for it..
will it fit on the HKS/Greddy Cast manifolds?
Old May 2, 2007 | 01:31 AM
turBRO240's Avatar
Certified Rotorhead
wow... nice find
even though im a major advocate of small fast responce turbos, but .78 A/R seems pretty small
is this turbo around the size of a GT30R or GT35R?
Old May 2, 2007 | 01:57 AM
No_Rotor_RX7's Avatar
i used to have an rhc7.. it had a 62mm inducer. not a bad turbo at all, very very responsive and pretty good top end to boot just watch your egt's
Old May 2, 2007 | 02:00 AM
Ottoman's Avatar
always modding
thanks for the replies...
how are IHI turbo's in general? are they reliable like MHI/greddy units? or fragile like some of the HKS ones?
so can it really handle 600hp as claimed?
I was looking to run it at around 1 bar...
Old May 2, 2007 | 02:13 AM
600hp... not happening. it's good for around 380 - 400rwhp
Old May 2, 2007 | 03:33 PM
twilight slide's Avatar
That looks broken
that 600hp rating was probably for a piston motor. . .
Old May 2, 2007 | 03:37 PM
more than likely.. i have seen mid 500's with the turbonetics 62-1's on a couple honda's here. either way that rhc7 will be a great street turbo
Old May 10, 2007 | 02:56 AM
kenn_chan's Avatar
Savanna Rx-7
IHI turbines
I have used IHI turbines extensivly for about 6 years. They were also the turbine of choice for Pan Speed and RE amamiya for about 8-10 years. the rhc-7 comes with several different configurations, however the one used the most with rotaries had the P18 or P19 exhaust housing which was a P trim wheel (P does not equate it just happens to be the same letters) with a split housing that was .78 or so.
the other common model read rb25, rb 26 or mega tuned SR 20 was the equivelant of a "o" trim wheel with a larger open valute houseing.
I recently swapped to garret due to availability (read pricing) of repair parts, the IHI turbines are as close to bullet proof as can be, but when the do need rebuilding they are expensive (at least here in Japan they are.
kenn
Old Dec 21, 2009 | 12:32 AM
jaila05's Avatar
rot8n'
not to be hackin ur thread but i have an IHI RHC7 Turbo t4 with Stainless manifold and 38mm wastegate flange, does anybody know who wants it? im selling it because i have sumtin else to drop on my 13bt.. thanks =P
BLK 93
Sep 28, 2015 01:45 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
jeremyferguson4444
Sep 19, 2015 01:27 PM
mulcryant
Sep 9, 2015 05:24 PM
